Thread: Soundproof material for Wooden Gate?
    Aug 2014
    Prosper, TX
    86
    Question Soundproof material for Wooden Gate?
    I'm trying to dampen the sound of my pool equipment, particularly the pump powering our water features. As a first step, I had a wooden gate put in.
    Equipment is on side of home, so we had a gate built in separating the equipment from the back yard...gate between side of house and the existing fence.
    It helped....a little. I'm now thinking of trying some sound dampening material on the back side of the gate, but I'm overwhelmed when I google the subject.
    Anyone here had any luck? I've also seen blankets and boxes to go over the pump, but I'm worried about ventilation. I figured this is the place to come for great answers!
    20,000 gallons, In Ground, Pebble Sheen, DE Filter, Jandy 2 Speed, Attached Ground Level Spa, Polaris cleaner with dedicated pump, Ozone Generator, TF 100 w/ SpeedStir
    foobert's Avatar
    Jul 2013
    Bay Area, CA
    143
    Re: Soundproof material for Wooden Gate?
    With the top of the gate open to the air, I doubt any amount of sound deadening material applied to the vertical surface is going to help compared to the sound going over the top of the gate.
    If you want to see what's possible, get a really heavy blanket (or three) and drape them over the gate down to the ground. If it really makes a difference, then, you might have hope for a more permanent material applied to the gate.
    ~john
    24.5K G, pebble, SuperFlo VS 1.5, 48sq DE filter, Hayward H250FDN, Autopilot RC-52, Poolvergnuegen & 3 daily swimmers in season.
    Aug 2014
    Prosper, TX
    86
    Is there a way to use a box or something over the pump? Is my worry about ventilation valid?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Do NOT cover the pump. They run hot.
