Thread: Warming the water
    Aug 2008
    Pensacola, Fl
    63
    Warming the water
    Does running the pump and filter help with warming up the water faster? Or no effect?
    My pool has been stuck on 82 for about 2 weeks, with mostly clear sunny days. We did have a temperature dip early one morning to about 49. That's cold, this is Florida.
    My pump runs at night, 11pm until 5am right now, mostly because that's when my electricity rates are lowest.
    About 23,200 gal vinyl in ground, "stop sign" shaped 22x22, Polaris 3900 cleaner, Hayward Aqua Plus Pro Logic Controller, Hayward T-15 SWG cell, Hayward S244T sand filter.
    Aug 2013
    Oklahoma City, OK
    158
    Re: Warming the water
    I would think that running it would actually cool it down but I have been wrong before. I am sure some one else will chime in.
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    I think the most it might do is circulate the top few inches of warmer water into the rest of the volume----insignificant. A solar cover will help you maintain any temperature you may gain on sunny days or minimize overnight losses.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Circulating the water at night helps cool the water down. Running the pump during the day won't heat it any faster. Easiest thing you can do is put a solar cover on the pool.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
