Thread: Fire pit near above ground pool
    May 2017
    Tinley Park
    1
    Is it possible the integrity of my pool will be compromised by the heat of a fire pit? It is about 10 feet away. I have a picture but cannot add attachment
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Fire pit near above ground pool
    Welcome to TFP!
    More on posting pics, Posting Photo's Tutorial
    Apr 2017
    sacramento CA
    147
    I doubt it.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    I really depends on what you call a fire pit. If its a small camp fire where the flames stay a foot or two off the ground yea you will probably be ok unless the prevailing wind is blowing directly at your pool. Maybe its a Northeast thing cause it gets cold up here but when I have a fire most times flames get higher than my head at some point and you stand 10 feet away because its way too hot any closer to the fire. I always plan on fires being twice as big as I plan them to be to get a good margin of safety for where I choose to set them.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    TomGallopavo's Avatar
    Apr 2016
    Hillbillyville, MO
    175
    Mine's about that far...burn eveything from oak to cedar.
    Spring 2016 Install, 24'x54" Saltwater LX AG Round Pool (13500 gal.), AquaPro 200 SQ. FT. Cartridge Filter System 2-HP 2-Speed Pump, Solaxx Saltron Retro Jet RJ Saltwater Chlorine Generator, Aqualuminator Above Ground Pool Light, TF-100 Test Kit w/ Borate and Salt, Well Water.
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    419
    i have never had a problem and mine is about 6ft away. mine is a chimenea so i really dont have to worry too much about flames or sparks.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
