Results 1 to 8 of 8
Thread: Pump sucking air
    Apr 2017
    Alligator, MS
    10
    Pump sucking air
    Hi, bought a home last November with a 15 by 35 fiberglass 22,500 gallon pool. Found TFP for advice on water chemistry and have a sparkling clear pool. Problem I'm having is with the pump sucking air. There's been a few times basket runs full but most of the time it's not. I've looked all around lid and basket housing for leaks or cracks when I shut pump off and can't find anything. It's a 1 hp motor and sta-rite 240 sand filter. Impeller is clean. Any advice? Thanks
    30,963
    Re: Pump sucking air
    Welcome to the forum
    Have you seen the article in Pool School?
    Pool School - Suction Side Air Leaks
    Apr 2017
    Alligator, MS
    10
    Just did now thanks. Sometimes it will run full for 20 seconds and then fill with air.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Quote Originally Posted by Terrys379 View Post
    Does it surge? That's a good sign your water level is too low, either because it's low in general or because the skimmer weir is sticking. Take a look inside the skimmer and check for a vortex. What happens is that the pump primes, gets going so well that it sucks the water out of the skimmer, loses prime, stops pumping, which allows skimmer to refill, it primes, gets going good.... and so on.
    Apr 2017
    Alligator, MS
    10
    It's not surging. Plenty of water in skimmer and the vortex is small.
    Richard320's Avatar
    Jan 2010
    20,312
    Shouldn't be a vortex at all.
    Apr 2017
    Alligator, MS
    10
    Found air leak 3 ft from pump underground fitting.
    Richard320's Avatar
    Jan 2010
    20,312
    Excellent!
