Hello all. I'm getting ready to buy and install solar panels and thought I would run my plan past those who know a lot more about these things than I do....just to make sure I'm not planning anything overly stupid. I'll try to include as much info as possible. I'm a commercial builder and have done much of the plumbing in my homes for years, I feel like I can glue a pipe as well as any apprentice plumber so will be attempting this project myself. The questions in my mind are design. I believe I've decided on Techno-Solis brand mostly because they are local and that appeals to me. Feel free to caution or wave me off if you feel there is a better option that a do it yourself type can get access to. I've read the install manual for them and a few others and believe I have a decent grasp on design needs. Pool is plumbed 1.5inch, two bottom returns and one skimmer. Pump has two inch from pump to filter and will be two inch to panels and back then reduced to 1.5 before going into the chlorine (may install SWG at same time). Intelliflow will be controlled by SunTouch though I am considering EasyTouch if for no other reason than it has a panel inside with temps etc and I can control the water features pump with it as well.
Pool is just north of Tampa Fl, looking to extend swim season as much as practical. 16X30 free form pool, screened, shaded in mornings. It's May 10th and water temp is 78 and has been there a couple weeks. Took until August to heat up to the 85+ last year that the wife prefers...and didn't last long. Looking to add solar to get it there sooner and keep it there longer. As you can see in the photo below (I hope it shows up below...and I apologize for my horrific photoshopping skills), the run across to the best south facing roof isn't terribly short. Eight 4x12 panels in a double stack. 5 on bottom and 3 on top will pretty much fill that section of roof. Is there a problem with 5 and 3? In keeping the heated water run short I'm going to feed the rows from the right and back to the pool from the left. I believe I can maintain fall on the piping to allow drainage when system shuts off. Relief valve on the right side of the upper row.
I'm sure I'll have questions along the way, but to get started.....If my drawing makes sense, does this plan look like a bad idea to anyone?
