- Jun 28, 2016
- 44
- Plaster
- CircuPool SJ-40
So I moved into a house with a pool last season. Used only liquid chlorine last year and not one issue. Today I woke up to a cloudy pool. Could still see the bottom, but cloudy for sure. Anyway I tested water and I was at 0 chlorine because I just ran out yesterday. I was in a bind so I used some shock I had bought before I found TFP. Anyway I added 2lb of Clorox shock plus. Active ingredient is sodium dichloro-s-triazinetrione. Let it run a couple of hours and it seemed more cloudy when I came back. Also on a couple of the ledges there was a white almost toilet paper dissolving in water looking substance. I brushed the entire pool and added another 2lbs of Clorox shock plus. Just curious if anyone knows what it is. BTW I took a sample of the water before adding the last two shock packs. Here are the TF-50 results:
PH 7.5
FC 7.5
CC .5
CH 275
TA 120
CYA 35
PH 7.5
FC 7.5
CC .5
CH 275
TA 120
CYA 35
