Thread: Pentair IC60 Cold Water Indicator but H2O about 85degF
    May 2017
    Bettendorf, IOWA
    2
    Hi ... need some help to know if there is an easy fix to the water temperature sensor indicating a cold water condition which surely is not the situation. As above - the unit is a Pentair Intellichlor Model IC60 and is only 2 years old. Many thanks to the loads of advice hopefully coming my way.
    May 2017
    Bettendorf, IOWA
    2
    Re: Pentair IC60 Cold Water Indicator but H2O about 85degF
    Quote Originally Posted by amannamedrobert View Post
    Pentair has a good customer service line for support - I was told a good cleaning will likely fix the problem (temp, flow and salt sensor are all contained in the same sensor assembly.)
    Small built in, 12k gallons, Pentair pump, SWG, and heater
    Oct 2015
    San Diego, Ca.
    801
    If you haven't cleaned the cell in 2 years, Pentair's advise is definitely worth a try.
    I like a muriatic acid mixture of 6:1 and rinse when the bubbles slow down. There is a coating on the plates that you don't want the acid to etch.
    Also, you'll need an end cap that screws on to one end of the SWG for soaking/cleaning https://www.amazon.com/Hayward-GLX-C.../dp/B002YLWYH0
    Lot's of YouTube videos on this procedure.
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
