Thread: Help
    Apr 2017
    Buffalo/new york
    4
    Help
    Hello everyone. I'm a newer pool owner and am having quite a hard time haha. So I struggled last year with chemicals and wasting money at the pool store. So I bought a k-2006 test kit and found my CYA levels to be over 100. So I decided to try and drain some water, well when I closed the skimmer to just use the main drain it seems like pressure built up and the pipe above my pump started leaking. I tried to take it off and retape it or glue it and of course it cracked. I did a little research and I believe it's a check valve used to prime. Correct me if I'm wrong. I'm in the process of buying a new one but I'm wondering why it started leaking. I run the filter daily and have never had an issue. Once it started leaking, I shut it off, reopened both valves back up and of course it leaked. Any help is appreciated, I'm feeling overwhelmed.
    25k gal, vinyl IG, 3/4 hp Hayward max flo, sand Hayward pro series, Polaris 9550 robot
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,968
    Re: Help
    A picture might be of some help. It is really hard to know what you are dealing with without seeing it.
    Kim
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Help
    Quote Originally Posted by Collinf View Post
    Yes, pictures please!
    Likely nothing you can't fix with a run to the local hardware store.
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    Apr 2017
    Buffalo/new york
    4
    Re: Help
    Can you tell me how to put pictures on here. Sorry but I'm new to the forum
    Jul 2012
    Tallahassee, FL
    33,968
    Re: Help
    You can use Photo Bucket or such using the IMG code.
