Thread: Missing backwash hose adapter for Intex sand filter
    Swenny's Avatar
    Jul 2015
    MN
    6
    I have no idea why this isn't included with the pump or why I couldn't find this info on TFP so I'm posting here
    If you're Intex filter has a threaded drain port that is approximately 2.25 inches wide and you want to use a roll up backwash hose, this is the adapter you need:
    Intex 10849 (also called Adaptor A)
    Intex link: Adaptor A With Collar (To Adapt Small Hose [1-1/4 Or 32mm] To Plunger Valve ) - Intex
    About $10 after shipping. Cheapest place I found. Hope this helps someone
    Intex Ultra Frame 20' x 52" AGP (28339TT)
    8,600 gallons, city water
    Sand filter, 1,600 GPH pump
    Jan 2012
    'burbs of Augusta, Georgia
    8,557
    Re: Missing backwash hose adapter for Intex sand filter
    Thanks for sharing this When folks use the search feature here on the TFP forums this will be helpful to them.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    May 2018
    Omaha
    1
    Thanks for the link!
    22x52 intex ultra frame, 2650 gph intex filter and salt water system . Omaha, NE
