This is my first time owning a pool and I'm getting ready to open my pool and mentally preparing what needs to be done. The pool is around ~40k gallons (I don't know the exact depths on either end...bought the house in November). Hoping to get some advice throughout the opening process. All I have to go on is a handwritten note by the prior owner.
I bought a test kit as recommended and tried checking out the water before opening to see if anything came from the levels, to practice using the kit, and also to see what my CYA was at. I wasn't able to get anything from the test and took a sample to the pool store. They said my water was "dead" and had no readings on it, but that's it's normal until you start opening the pool (something about chemicals sitting on the bottom).
My pool is definitely going to need slammed but I know the SLAM level depends on the current CYA. Should I operate on the assumption that CYA is 0 and add chlorine to bring it up to Shock FC of 10 and check the CYA after a few days? Should I go through and fire up the pump/filter and begin scrubbing/vacuuming the pool out (a lot...seriously a ton of water needs to be wasted out...it's completely full due to a TON of rain over the winter and recently) and test after that to see where it sits before adding chlorine? I'm sure that this isn't rocket science, but I'd also like to make sure I'm doing it properly to open my pool as quickly as possible. The kids are getting restless...
Here's a current pic for reference. You can see that the mild winter has not been nice to the pool...but I know it can get crystal clear because we saw it when we first saw the house and it looked gorgeous. Would like to get it back there ASAP!
