What are these on bottom of my pool?
Dec 27, 2010
117
El Dorado Hills, CA
I have what appears to be a drain like the ones in my spa on the bottom of my pool in the deep end. I assume it's hooked up through my skimmer given what I've read.
In the shallow end and between the shallow and the deep end, I have three other "things" that I don't recognize. What are these and what do they do?
Ed
No, that is very unlikely. Without valves controlling suction and return lines you would not be able to isolate the spa to heat the spa water without also heating the pool water.
