Results 1 to 11 of 11
Thread: pump outlet still leaking.Uggggg..
    Jan 2010
    Randleman,NC
    620
    I'm at the end of my rope's.I continue have a small leak from the Hayworth Power-flo pump outlet on the 1.5 inch male PVC connection.I have teflon taped and taped and still can't get it to stop.I'm thinking about just going to the female screw down with a gasket if that is possible.Not even sure what size the outside threaded side is.Any suggestion's?
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,728
    Re: pump outlet still leaking.Uggggg..
    Hi, can you post a picture of the problem area? That will help us advise you better.
    Love TFP? Become a
    TFP Supporter!
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by zea3 View Post
    I have re plumbed twice and have had leak's three time's now.Getting kind of expensive because of the hard plumb.Only thing I can figure is cut again and add more tape.lol
    Quote Originally Posted by kplaster View Post
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,265
    K,
    You don't need tape, you need to use pump unions. They have an O-Ring on the threaded side..
    They look like this...
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by Jimrahbe View Post
    K,
    Are they a 2in to 1.5 .There are pricey.Where is the best place to get them?Wondering if I could use a rubber gasket on the bottom of the adapter I have now.
    Jan 2010
    Randleman,NC
    620
    Just went out to check on it .It's also leaking on the input on multivalve.Had to replace this section this morning because when I cut the pipe to tighten it up last week.Didn't get one of the 1.5 to 1.5 connection sealed good and was leaking.Uggg!!!!
    Jan 2010
    Randleman,NC
    620
    K,
    Again,where can I find these in 1.5 male thread?????All I have seen is 2 in.Hayward has a male threaded Union.But,with no gasket.
    Jul 2014
    Bedford, TX
    9,265
    How about this one... https://www.poolzoom.com/union-cpvc-...-w-o-ring.html
    Jan 2010
    Randleman,NC
    620
    Thanks Jim.Will be ordering a couple of them.Price not bad
    Jan 2010
    Randleman,NC
    620
    Jim,just got done ordering 3 of them.Two for the pump and one into the filter since I can't get it to stop leaking.Willlet you know how it goes.Thanks Again
    Jan 2010
    Randleman,NC
    620
    Project complete.Had to go back and teflon tape more till it stopped leaking.Also,make sure you place the strainer lid in the position so you can get it open and off.The handles will not make it by the union coming out of pump.
