Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Acid eating beauty....
    Jun 2016
    Locust Grove, GA
    62
    Hey everyone....second season with the pool now and have had nothing but crystal clear water from day one since becoming a TFP follower....
    Yet, I can't seem to get a handle on the pH. It wants to stay high all the time no matter how much acid I feed it. TA is right at 100 at the moment, but have always kept it in the 80-100 range. All other chemistry is normal range.
    This is a 42k gallon swg gunite/quartzscapes finish built last spring. Am I doomed to feeding this thing a gallon of acid per day for the rest of my life?
    50x20 IG, quartscapes finish, 41k gallons , Autofill valve, Jandy pro series stealth 2 HP pump, Polaris PB4-60 cleaner, 4 cartridge filter (unknown make), Hayward Turbo cell 15 swg, Rheem 135k BTU heater/chiller, Hayward Pro Logic control panel, pool build complete 6-10-2016
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,268
    Re: Acid eating beauty....
    That's a lot of acid. What are you trying to keep your pH at? My pool loves to be at 7.6-7.8. So, I let her hang out about 7.6 and try not to force her to be 7.2. What is your water source?
    Jun 2016
    Locust Grove, GA
    62
    We have county water. Really really nice water. Trying keep pH under 8 but not having much luck.
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,268
    You can try lowering your alkalinity Pool School - Lower Total Alkalinity it is a tad high. What are you testing pH with?
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    You may want to consider adding borates to your pool there is a good thread explanation about how they can help Here
    Also the Borates why and how which is Here.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,277
    MD,
    When you add MA are you shooting for 7.2 or 7.6? Most saltwater pools like their pH around 7.8...
    Lowering your TA, using the link that OTPirate provided above, works well for me...
    Jun 2016
    Locust Grove, GA
    62
    Thanks everyone. I will give the borates a try.
    Jun 2016
    Locust Grove, GA
    62
    Quote Originally Posted by OTPirate View Post
    Testing with a pool master drop kit
    30,950
    Lower your TA down to 60-70 before borates. See what that does. Then, if you still struggle with pH, try the borates.
    You should get a good kit.....how old is yours?
    Jun 2016
    Locust Grove, GA
    62
    Added two gallons of acid this morning and pH is now at 7.6 and TA at 80....
    Gonna add another gallon and see how that goes. The kit I have is less than 12 mos old.
    Jun 2015
    Mandeville, LA
    109
    My pool is about the same age. The acid demand slowed down a lot once I got TA to 60. Also as said above it seems to like to ride at 7.8 so I only knock it down to 7.6 when adding acid.
    Completed April 2016: 22x36 3.5-5.5-4 Inground, 17,500 gallons, Aquapure SWG, Jandy 2hp Variable Speed, Jandy 460 Cartridge Filter, Polaris 280, Aqualink PDA4, Jandy Nichless LED lights, Diamondbrite color Steel Blue, Noche Travertine Coping & Deck
    Jun 2016
    Locust Grove, GA
    62
    Good to hear. Maybe I won't need borates after all. Just don't want to put $8 worth of acid in it everyday. That will start to add up.
    Jun 2016
    Locust Grove, GA
    62
    $3000 a year for acid and I will probably just let it ride.
    Apr 2017
    sacramento CA
    147
    My swg pool rides right around 7.8 like JR said above. I've been trying to reduce my TA from 140 to 70 by getting my ph to 7.2 and aerating. It's just not working for me. So I'm just moving on and living with it.
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,268
    Ok, I'm terrible at colors, because that looks like 7.6 to me. I like to use a pH meter in conjunction with the pH test.
    triptyx's Avatar
    Apr 2016
    1,476
    I read it as 7.6 as well OTPirate.
    MolarDog - start by lowering your TA to around 50 as recommended above. Do that in conjunction with keeping the pool around 7.6-7.8 and I think you'll find your acid demand drops quite a bit.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Quote Originally Posted by triptyx View Post
    +1 to lowering TA to 50 or 60.
    Jan 2012
    'burbs of Augusta, Georgia
    8,577
    Keep in mind your pool is also still kind of "new" and some will take a year or so to finish curing.
    Don't try borates until after your TA/pH have been stable a while. If you do it too early they become harder to manage if you need to change something.
    Maddie
    (and I know you didn't ask but... you need a FAS-DPD tester. So you can test chlorine >5ppm)
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Jun 2016
    Locust Grove, GA
    62
    Thanks everyone. Gonna go buy a pallet of acid from home Depot and conquer this TA....still reading 90 and pH has already crept back up to 8.2 as of this evening.
  20. Back To Top    #20
    Jun 2016
    Locust Grove, GA
    62
    And btw, I have Taylor test kits for every other parameter....salt, calcium hardness, fas-dpd.
