Results 1 to 7 of 7
Thread: Need new Spa pump - with pool renovation
    May 2016
    Arlington, TX
    225
    My secondary pump for my spa needs to be replaced. It is a 2HP Hayward. I am trying to go all Pentair but not sure which route I should take with this pump. Just a standard pump?
    Thanks
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Need new Spa pump - with pool renovation
    Which Hayward pump is it? Pentair will have a pump that is directly comparable to the pump you are replacing.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2016
    Arlington, TX
    225
    My bad, it is a PAC-FAB Challenger (I guess they are pentair now?).IMG_3844.jpg
    May 2016
    Arlington, TX
    225
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    A superflo pump won't replace that pump. Challenger pump are high head pumps.
    Whats wrong with the current pump? Chances are its fixable for less than the cost of a new one. If you are planing on staying with pentair I would recommend getting the same pump you already have.
    https://www.poolsupplyunlimited.com/...l-pump/69447p1
    Chuck-
    May 2016
    Arlington, TX
    225
    Thanks, it is about 20yrs old. We turned it on and it was hung up and then shot water all out the seal. I am sure I could fix it (have worked on all my pumps) but I am ready to just get a new one. It will complete the cycle of my pumps being replaced. That one is fine. What is a high head pump?
    thanks again!
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    In so many words it can keep up a high flow rate with a high back pressure.
    Chuck-
