Thread: 1.5in to 2in transition
    Sep 2016
    Irwin, PA
    2
    Hi,
    My new pump and filter have 2in connections. My existing return and pump lines are 1.5in flex pipe. Should I transition to 2in right where they come out of the ground, or as close to the pump and filter as possible?
    Rick
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,302
    Re: 1.5in to 2in transition
    I'd do it closer to the ground. The larger internal diameter elbows will flow better.
    Sep 2016
    Irwin, PA
    2
    Thank you!
