Thread: Hayward Microclear 48 leak
    Jun 2016
    Readington, NJ
    3
    I just opened my pool yesterday and I ran into a few issues. I managed to repair all of them except for one. There is a very small dripping leak on my filter where the multiport valve connects to it.
    The leak is on a part that appears to be discontinued ( see and look at part 19 on this page Hayward Micro-Clear DE Filter Parts (Also sold as Leslies Crystal Clear II) )
    I can buy a replacement O ring to see if that fixes the problem but if it is the discontinued piece that is leaking, does anybody have advice on how to handle that? I don't really want to replace a filter that is doing its job well over such a small leak. In reality I could probably leave the leak alone and never notice anything because it is so small. However, it is going to bother me and I want to fix it.
    See the attached image (there is a large amount of water on the ground but that was caused by my mechanical ineptitude, not the small leak)hayward leak.jpg
    Thank you for any help and advice!
    In ground concrete ~19,000 gallon pool. Hayward Micro Clear 48 sq ft DE filter and Hayward Superpump, SWG
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Hayward Microclear 48 leak
    If nothing is cracked it's likely an o-ring.
    If that's not the answer you could use some teflon tape on the thread or even some clear silicone to seal things up.
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
