Hello TFP land! IT's warming up - time to get into full gear.
I have an ancient Clearwater II cartridge filter and some replacment pump. I believe the pump is overpowered (it literally forms a lazy river in my pool).
It is pretty good at keeping my water clean, BUT it sucks. The motor is loud, has two speeds, but only one speed works, I have lots of drips here and there around the pre-filter basket, the pressure gauge doesn't work (I've replaced it twice in the last 4 years) is a 240 V pump. I can never put this thing on a timer because at times things pop off (i've had the pressure gauge crack off, hose pop off etc). Again, because I think the suction side is so strong. I see whirlpools and hear gargling.
Okay - so enough justifying WHY I want something better.
So I want something slow, quiet, that I can mostly set and forget. My pool gets lots of sun, but also lots of shade in the evening (past 6ish). Lots of leaves in the fall - in fact, with my current pump, the suction is so strong that in about 1 hour it will choke the skimmer with leaves.
I use an aquabot pool rover to clean the bottom so I'm hoping that I can go with a weaker pump and keep my water safe and clean.
Are these things any good? https://www.walmart.com/ip/Intex-Krystal-Clear-Sand-Filter-Pump/33153775
I see the Polaris setups that are literally 10x as much - do folks see a 10x improvement? Since the Intex also has a SWG add-on, I'd eventually like to replace my SWG too (again, it's an older unit - that isn't made anymore).
Downsides to keeping my pool clean with a cheap walmart filter and an aquabot?
