Thread: Hot springs vanguard no power kind of
    May 2017
    waynesburg
    1
    I have a hot springs Vanguard. I did a water change and clean the tub. Refilled the tub and flipped the 20 and 30 amp breaker to restart the tub and now the only thing that is working is the recirculation pump. I took off the IQ 2020 panel and noticed the bus status light is green and when first powering on the Lim Ok light is green. After about 10 seconds the lim oK light goes out and the controlled unplugged light turns red. Prior to the water change everything worked the way it should. Anyone have any suggestions?
    Jun 2014
    17,326
    Re: Hot springs vanguard no power kind of
    Hello there Rich and welcome to TFP! Have you had any luck on your issue yet? I don't have a Vanguard so I can't personally relate to your issue, but perhaps others do. I'm hoping this to get your thread to the top of the forum front page will help. Feel free to reply back to keep it visible if you haven't already resolved your problem. At the very least, as a new member, I wanted to ensure you knew we weren't ignoring you, just giving your post some time to be read by someone who may be able to help.
    Enjoy the rest of your weekend.
    Sep 2016
    Grand Prairie TX
    50
    Check this link which I just found because I refilled my Aria model. See 2.B., which I never knew about or have in my owner docs. They specify flipping breakers in certain order with running jets in between.
    Hope it helps.
    Hot Tub Start-Up Refill - Northwoods Hot Spring Spas - Michigan
    19x32 Freeform Gunite IG pool, 14,500 gallons, 3.5 x 5 x 4, 313 sq ft decking, AquaBright(Blue Mist), 2.0 HP Jandy EPump,Cleaner Booster pump, CV 460 SqFt Jandy Cartridge filter, Aqualink w/PDA, Fusion-Salt System, 2 LED, Jandy Heat/Cool Pump 140K BT, Polaris 3900 w/Pump My Build
    Jun 2017
    Chula Vista, ca
    26
    Thanks for that tip on the order to flip the breakers.
    Hotspring Grandee NXT, ACE SWCG and Dichlor/Bleach method combined, 450 gal, K-2006 and K-1766.
