Been utilizing the pool for the last four days since the heat pump finally got our water warm enough. It took 96hrs straight of running the heat pump to get to the upper 70s. It's quite brisk outside now (mid 60's) but the water is a toasty 88 degrees (we've been swimming at night because of our schedules).
The PB initially started up the mechanicals and said they put in the appropriate chemicals. When I first tried to balance the water, I would pour a whole jug of chlorine at night and the FC would be around 12. The next day I would be at zero. The PB said they put in stabilizer but when I tested the water it never got cloudy and I could always see the black dot and I thought my test was faulty but apparently I had 0 CYA. Once I put in 12 lbs of cyanuric acid, everything was fine and my chlorine stayed very consistent. I only have to put a tiny bit of liquid chlorine every other day. I also added a few boxes of baking soda to get my pH and alkalinity up and right now my water is crystal clear, doesn't smell and my latest test shows the following:
FC - 5
CC - 0
pH - 7.5
TA - 130
CH - 50
CYA - 40
As far as I can tell, the TFP method seems to be working out. All of my friends who have pools and use pool store free-testing say they struggle with bouts of green water and cloudiness which I hope to avoid. I guess we'll see how it goes. Wish me luck!
FC - 5
CC - 0
pH - 7.5
TA - 130
CH - 50
CYA - 40
