Need to replace the whole light and housing in my hot tub. Before I jump in and end up doing things the hard way I had a few questions.
1. for the pull line to attach to the cord, some poly pull line adequate or is there something specific suggested? amazon: Klein Tools 56108 Poly Pull Line?
2. Both the pool and hot tub lights go to a junction box outside my main control box. Any suggestions on figuring out which is which or is tugging and watching my best option? EDIT_ I figured this out. I'll just disconnect and put string to both then pull from hot tub end and only the correct one will go. That's that!
3. Draining my hot tub - Plugging the hole that lets water flow from pool to hot tub, any suggestions? are there any products specifically made for that or grabbing ball from my kid and letting the water pressure hold it in place a good bet?
I replaced all the light fixtures around my house, so I am not afraid of the electrical work part of it. BUT, any suggestions/tips are more than welcome.
Thanks in advance for any help, this site has been a wealth of knowledge!
