Results 1 to 8 of 8
Thread: Spider Gasket for Hayward S310T2 Pro Series Sand Filter?
    Paul & Crystal's Avatar
    May 2014
    Oklahoma City, OK
    539
    I've been looking on line for a spider gasket for the Hayward S310T2 Pro Series sand filter. All I'm coming up with is full multiport tops. Does anyone know if this model has spider gaskets for DIY? If so, can you give me the model number and/or where it can be ordered? I've read that some sand filters do not have an accessible spider valve and cannot be done DIY.
    Thanks!
    Crystal
    60K 53 X 23 X 3'-10' IG Grecian Concrete aka "The Beast"
    TF100 XL with Speed Stir
    Dolphin M500 aka "The Beast Master"
    Sta Rite Max E Pro 2 HP - Hayward Pro Series Sand Filter S310T.
    My Pool Thread: Old School Pool
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,994
    Re: Spider Gasket for Hayward S310T2 Pro Series Sand Filter?
    Have you checked out inyopools.com? Huge selection of parts there.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    May 2014
    Oklahoma City, OK
    539
    I will call them tomorrow if I can't find anything...I'm sure they could figure it out.
    Thanks!
    22,701
    The spider gasket for that valve should be SPX0715D. It fits the SP0715 & SP0716 valves. If you search that number you'll find measurements so you can double check it.
    22,701
    The spider gasket for that valve isn't too hard to change if you're a little handy.
    Here's a set of instructions on how to replace it. It's slightly generic, but it's good enough that you'll get a good idea of how to do it for your valve.
    P.S. Pat asked me to post this.
    May 2014
    Oklahoma City, OK
    539
    Hi Bama Rambler!
    Thank you so much! I will check this out. I am gearing up for a deep clean and overall rehab maintenance for sometime in June. I have small leaks both on the top around the handle and around the seal where the cap fits onto the tank. Maybe I need an O ring as well?
    Crystal
    22,701
    I think they sell a rebuild kit that has the spider gasket and the O-rings for the handle and top housing and maybe even the vessel o-ring. check prices though, because it may be cheaper to buy the whole valve than the individual parts.
    May 2014
    Oklahoma City, OK
    539
    Ty Bama!
    I actually would not even mind replacing the entire valve if it's not too expensive because it is pretty worn looking.
    Crystal
