Results 1 to 15 of 15
Thread: CYA Test. No Reading?
    Jun 2014
    Chandler, Arizona
    88
    When I test my CYA, I literally fill the cylinder to its rim and can still view the black dot on the bottom. What should I assume is my reading? 10? 5? 0? And am I to also assume I have no stabilizer in my pool? Pool math indicates I should add 97oz of it to reach 30. This is the first year I've tested in April and experienced such a read so am a little alarmed.
    I bought 2 of these earlier today: Pool Time 23417PTM 5 lb. Chlorine Stabilizer .
    How would you recommend I distribute it into my pool? The directions say to spread in throughout my deep end but my pool vacuum would quickly suck it up.
    Thanks!
    28k gallon in-ground pebbletec pool w/waterfall and grotto feature
    Triton II sand filter
    "The Pool Cleaner" 4-wheel vacuum
    1.5hp main pump; 1.5hp water feature pump
    Taylor K2006 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,303
    Re: CYA Test. No Reading?
    Assume it's twenty and work up to it in steps so you don't overshoot.
    How to add the various chemicals is explained in Pool School - Recommended Pool Chemicals
    40,878
    So you had cya when you close now you opened and you're not showing any? If so you might want to do a test to see if you have ammonia before adding any cya. Just raise the FC to 10 PPM and retest in 10 minutes and Report the FC and CC.
    Jun 2014
    Chandler, Arizona
    88
    Thanks, Richard.
    One more question: Should I shoot for a 30 reading? The chart indicates anything between 30-60 is acceptable but what is considered optimal?
    Richard320's Avatar
    Jan 2010
    20,303
    Quote Originally Posted by asusundevil View Post
    Thanks, Richard.
    In Arizona, shoot for 50. Some people even go higher. But again, it's really easy to add more, hard to eliminate excess.
    Jun 2014
    Chandler, Arizona
    88
    I reside in AZ so we don't close/cover our pools. Essentially, throughout the winter I test maybe once every three weeks. When it begins to warm up, like it has been the past month, I begin to prepare for the summer. Today was my first CYA test of the year. Unfortunately, I can't remember what it was when summer ended last year but know it wasn't 10-20.
    Is the high risk of algae at a lower FC level the rationale behind folks in AZ shooting for 50
    40,878
    No the higher cya protects FC the from the Sun.
    We've been swimming for over a month what you waiting for
    Jun 2014
    Chandler, Arizona
    88
    Man, swimming already for a month? That's, as they say, "cray cray."
    So each of these containers of stabilizer I purchased from Home Depot is 5lbs. When I use pool math, its recommended I distribute 112oz (by weight indicates 7lbs) or 117oz (by volume). When I hold one of these 5lb containers in my hand and visualize pouring the entire thing into my pool, +2 additional lbs, it makes me uncomfortable. As such, I instead poured 1/2 of the 5lb container into my skimmer (with skimmer sock).
    Just tested and here are my numbers:
    CYA - Assuming 20
    PH - 8.2
    FC - 4
    CC - 1
    TA - 100
    CH - forgot to test
    Apr 2017
    Tucson AZ
    81
    Isn't 50 a little low for a SWG pool? I thought the recommendation was 60-80. I'm in Tucson also - mine is currently 100 due to a Leslie's mess up.
    In-Ground Pebble Tec installed 2005/10,000 gallons/Magna Sweep cleaning system/RJ-30 Circupool SWG/Rock Waterfall/Hayward Ecostar SP3400 VS pump/Hayward Swimclear C3025 cartridge filter/Hayward H400IDL2 gas heater
    Jun 2014
    Chandler, Arizona
    88
    Dooger54 - Not sure if your question was in reference to my pool but mine is not salt water.
    30,950
    Get your pH down to 7.5 or so, then proceed.
    Apr 2017
    Tucson AZ
    81
    I was referencing jblizzle pool. Just questioning why he keeps his salt pool at 50 CYA. everything I read here suggests 60-80. I would think the sun here in Tucson would make the goal closer to the 80 number. Course I'm new here and could be completely off base.
    40,878
    Who says I keep it at 50? I keep mine at 80, or I did when I was running SWG last year. Cell died and I have not replaced yet.
    Richard was talking about targeting 50, with the assumption of a non SWG pool.
    domct203's Avatar
    Jun 2015
    CT
    3,898
    CYA - Assuming 20
    PH - 8.2
    FC - 4
    CC - 1
    TA - 100
    CH - forgot to test
    Next CYA addition, put the CYA into an old sock, close up the end and hang it in front of a running return. With a bit of squeezing it will dissolve in no time.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Apr 2017
    Tucson AZ
    81
    My bad. Went back and read again. Wasn't criticizing, just trying to understand so I can get mine right.
