Results 1 to 8 of 8
Thread: How do you all deal with flowering trees?
    May 2013
    Needham, MA
    151
    Had the solar cover off today to run the Polaris and brush the pool. It was snowing green from the flowering trees. I left the cover off for a bit to let the skimmer catch them with a skimmer sock. Wind picked up and too much was getting into the pool. I could not take it any longer so I put the cover back on. Now it storming out and these things are falling like crazy! I have never seen these before in my yard, or at least never paid attention to them as this is my first spring with the pool. What is the best way to deal with them?
    14x28 Kidney IG vinyl pool, 9250 gallons. Pentair 1.5hp superflo variable speed, Pentair Clean and Clear 240 Cartridge filter, Pentair IC40 SWCG, Hayward Heatpro 110,000k heat pump, Pentair Intellibrite 5G LED lights, Polaris 280, Taylor K-2006 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: How do you all deal with flowering trees?
    or
    I stopped bothering with a cover. I never could remove it without all that stuff ending up in the water anyway.
    PS. Skimmer socks/ nylons/ hairnets will help a lot to keep your filter from loading up. Use the search box on any of those terms and you'll find a lot.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,729
    My neighbors have Crepe Myrtles that drop pink blossoms in my pool all summer long! I use a PoolSkim USA -- award-winning automatic pool skimmer solves and eliminates your pool debris problems for a clean and sparkling pool. to collect them when my pump is running. There are other products that can help as well such as a skimaround or a pooldevil. Other than that, covering the pool until everything quits falling, frequent vacuuming, or removing the tree are the only other options I know.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    One day at a time is all I have to offer.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    My solar cover looks like that too. When we swim during the week we fold the cover back and grab what we can. Then on the weekend we take the cover off, clean it up and net out whatever falls into the pool.
    Apr 2015
    tucson, arizona
    1,314
    Chainsaw
    GoGrabTheNet's Avatar
    Dec 2015
    Phoenix, AZ
    65
    +1 to the skimmer sock/mesh. Total filter saver!
    A technique I've used before is to use the garden hose with a high-pressure spray nozzle and blast all the flowers/debris towards the skimmer (with a sock). Then roll up the cover.
    13k Gal. PebbleTec IG pool : Pentair IntelliFlo VS pump : Hayward 8-cartridge filter system : A&A in-floor cleaners : Jandy 115k BTU heat-pump : A&A auto-filler : Stenner 45MPHP10 auto-chlorine feeder : BBB Method
    Oct 2016
    Tampa/FL
    20
    Roundup 365...
    15,500 gallon outdoor in-ground SWG 16'x30' plaster pool; 7' Raised Spa; Jandy 2.21 HP ePump VS Pump and JEP-R Controller; Jandy DEV 60 DE Filter;
    Jandy JXi 400 Gas Heater; Jandy Nicheless LED Lights; AquaCal Pool Pilot Nano Chlorine Generator; KrystalKrete Blue Quartz Pool Finish; Screen Enclosure w/ Travertine Pavers; In-Service Date: 01/17
