Thread: SWG questions
    Jul 2011
    Las Vegas, Nevada
    139
    SWG questions
    I picked up a couple brand new Jandy Apure35plg systems as shelf-pulls. I was originally planning sell one to help offset the cost of the other, but now I am wondering if it would be beneficial to just keep it and install one on the pool and the other on the spa. It seems it would help on those days it needs a boost. I only paid $600 for both, so it wouldn't hurt me to keep both. ALSO, is it better to run these one 120v or 240v?
    Jay...12,500 gallon freeform pool and attached spa w/ Bullfrog Oscillator & ClusterSpray Jetpaks
    Jandy 2hp VS pump(main), Jandy 2hp Stealth pump(Jetpaks), Jandy 1hp Stealth pump(water features) Jandy CL-580 filter, Jandy Watercolors LED lighting, Jandy Aqualink RS8(revision MM) w/Aquapalm, Autelis Controller, Onetouch controller, Jandy Aquapure 1400 SWG, Jandy LXi 400k heater, Paramount PV3 6 zone infloor cleaning system
    Jun 2011
    Long Beach, CA
    2,891
    Re: SWG questions
    I would not run a separate SWG on the spa. Whenever you do use the spa I would suggest to turn the SWG off so it does not over chlorinate the spa. Spas are very small bodies of water and a SWG running can over chlorinate it.
    It makes no difference to run it on 120 or 240. I recommend to keep it simple and to run it on what you have the other equipment running on.
    Jun 2016
    Martinez, CA
    241
    Re: SWG questions
    You might consider installing both as that cell has a pretty small chlorine output compared to most systems (12oz/24hrs vs. 1.4lbs/24hrs for the jandy 1400 aquapure) that I have. That way, in the peak of summer you wont be forced to run the pool pump extended hours or add bleach due to the single cell not being able to generate enough chlorine to maintain desired limits and when demand is low, you,can turn one unit off.
    Although that model says it will work on pools up to 35k gals, you would likely have to run the pump 24 hours a day to do that. To give you a better picture, I run our 18k pool's filter pump 8hrs per day in summer with the 1400 set on 100% and will have to add chlorine occasionally to maintain an adaquate chlorine level. My pool is in full sun most of the day and I keep the pool ~85 degrees which increases chlorine demand.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    Jul 2011
    Las Vegas, Nevada
    139
    Re: SWG questions
    I'm not too worried about over chlorination of the spa, I have a large Palo verde that is constantly dumping deBristol in it. I usually drain the spa into the pool and then fill it back up when we get in it because the water is always a bit cloudy and with all the leaves and flowers, that's just the fastest way to clear the water. I may just sell them both and get the 1400 like I had in my last pool. I never had to buy chlorine with that system.
