Results 1 to 10 of 10
Thread: Chlorine level not budging, still hight
    Luric's Avatar
    Aug 2015
    Central NJ
    84
    We just converted to SWG and opened about 3 wks ago. Since then our chlorine level has been around 10/11. I turned the salt output from 80 to 50, to 30 over the last week, and it just tested at 10 still. The salt level has dropped from 3200 to 2850 to now 2650 (below the recommended level). What should I be doing? Also, what should we NOT have done to start with so we don't repeat this problem again?
    Levels:
    FC: 10
    pH: 7.5
    CH: 450
    TA: 160
    CYA: 40
    FWIW - I am NOT finding a SWG "easier" or less of a hassle than our traditional pool was...
    Inherited 30k gal IG gunite black bottom pebble w/ waterfall & attached spa, built 1993ish; Pump: Pentair Intiliflo VS pump; SWCG: Pentair IC60; Filter: Pentair FNS Plus 60 SQFT DE; Heater: Pentair Mastertemp 400,000btu; Robot: Dolphin Nautilus Plus; Waterfall Pump: Hayward Super Pump 1.5 HP; Testing: TFTest Kit TF-100; Automation: ​EasyTouch w/ ScreenLogic
    Mar 2016
    Chino Hills, CA
    190
    Re: Chlorine level not budging, still hight
    Salt water is easier than non salt, at least for me. You just need to get it all dialed in. I'll let the pros make suggestions.
    30,000 Gallon Pool IG (Pool 18' X 38' / Spa 7' X 7') - Pentair IC40 SWG - (1) Pentair Intelliflo 2 VST Pump - Pentair DE FNS-Plus 60 Filter - Pentair Mastertemp 400 Heater - Pentair Easytouch 8 - Pentair Electronic valves - Pentair 5G Color LED Pool/Spa Lights - Pebble Sheen Mini Tahoe Blue - Auto Fill/Over Flow - Taylor K-2006C - Completion 3/2016.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    What is your pump run time??
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Zappafan's Avatar
    Aug 2014
    Hampton, IL.
    151
    They recommend on here a higher CYA value than where you are at (60-80) for SWG pools. I don't know how much that will affect your issue other than holding more in reserve.
    17K Gallon,IG Vinyl,1hp Pentair Challenger,Pentair TA60 Sand Filter, Hayward Colorlogic,Re-lined 06-20-15, TF-100,SpeedStir,Lagunitas and Margaritas. Zappafan Pool Build
    Luric's Avatar
    Aug 2015
    Central NJ
    84
    KYWILDCATS - It runs on HIGH for 9 hr during the day and LOW for 5 hr overnight. Now that i'm reading that it seems an awful lot, doesn't it? I know the pool guys increased run time because we constantly had debris floating along the top, though to be honest, I'm looking at the pool now, and the increased time has not cleared the waterline.
    Luric's Avatar
    Aug 2015
    Central NJ
    84
    Quote Originally Posted by Zappafan View Post
    I noticed that, but wouldn't a low CYA level make me burn off more chlorine? Mine hasn't really moved all week :/
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Quote Originally Posted by Luric View Post
    I'm no expert, but mine only runs about 6-8 hours a day in the middle of summer. I haven't even turned mine on yet, I am using Liquid Chlorine (Bleach) until my water temp comes up more. I would say your pool is still pretty cool in your location.
    Mark
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    What is your water temperature?? Your SWG will continue to give you erratic salt readings until water is above 70 degrees. Most folks wait to turn their SWG's on but don't trust the salt readings until well over 60 degrees.
    I can't remember all the details, but the cell uses temperature as part of the salt reading calculation. If you add salt, you risk the actual level being too high for the unit to function once temps rise.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Luric's Avatar
    Aug 2015
    Central NJ
    84
    The water is about 65. Should I turn it off for now or just turn it down to like 5-10%?
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    I would turn it off and save on the cell life. Keep testing though, and just use bleach until your water temp gets closer to swimming temp. Just my opinion though!
    Mark
