Bleach will not help lower your PH. You need to buy muriatic acid for lowering PH. Do you know the volume of your pool? If so click on the pool math tab up top and plug in your numbers. It will tell you how much of what chemicals to add.
DS, can you please fill out your signature? That helps us SO much as the info is on each of your posts.
Go to settings (upper right of this page), edit signature (middle left of that page). Put in pool kind, size in gals, type of filter, what test it and any special features your pool has.
