Thread: Test results - first time opening using TFP method
    LoraT's Avatar
    May 2016
    Owensboro, KY
    40
    I started using the TFP method pretty early on last summer. IT. IS. AWESOME!!!!!! However, this is my first time opening without the "help" of my local pool store. Here are my readings:
    FC - 0
    CC - .5
    CYA - 30
    TA - 70
    PH - 7.5
    CH - 125
    I added enough liquid chlorine per pool math to bring my chlorine up to 4 ppm. I am wondering if I should bring it up to shock level since my CC reading showed a .5. Water is crystal clear - only had about 1,000 worms to vacuum out! If I don't need to shock, should I go ahead and add MA to bring my PH level up to 7.8?
    Thanks!
    12,000 gallon, in-ground, vinyl liner pool, TF-100 - City water
    Hayward Super II 1-Horsepower Pool Pump and Hayward Pro-Series S244T 24-Inch Top-Mount Sand Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,311
    Re: Test results - first time opening using TFP method
    Acid will lower pH, and yours is fine right where it is anyway.
    Just vacuum and brush and maintain FC. When you're confident it isn't going to go south on you, then raise the CYA a little.
    LoraT's Avatar
    May 2016
    Owensboro, KY
    40
    Thanks so much for your quick reply. Will continue cleaning & monitoring
