Thread: First time new Pool owner....help with the SPA
    rcee14's Avatar
    Apr 2017
    temecula /CA
    2
    TFP,
    I am a newbie I have a spa that flows water to the pool....TFP I need your help, when I turn on the pump the Baracuda G3 vacuums the pool, but I have notice the spa still has dirt at the bottom, the previous owner left no detail on how to work the equipment.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: First time new Pool owner....help with the SPA
    Welcome to TFP,
    You may just have to brush, or manually vacuum the spa until it's clean enough for you.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    I'm one of those Luddites with a manual vacuum. But my technique might work for you.
    I move the valves so I'm drawing from the spa and returning to the pool. As the spa level drops, I brush everything to the drain. Then I reverse the valves and vacuum the pool. The spa refills and I don't get any currents in the pool while I'm chasing stray bits of stuff.
    Do you have some kind of automated system, or have you just not figured out the valves yet? Post some pictures of the equipment if you need help figuring out what goes where, or what controller you have. I'm sure you can find a controller manual online somewhere if you know exactly which it is.
    rcee14's Avatar
    Apr 2017
    temecula /CA
    2
    This is my layout, I also notice the water level dropped as well20170425_174238.jpg20170425_174637.jpg20170425_174643.jpg
