OK, so a few questions here. Pardon my ignorance on this topic: I know NOTHING about pucks, since I've been reading TFP since prior to purchasing the pool and know that they are a bad idea as a maintenance plan as they UP CYA. My pool maintenance plan is completely TFP...
Reasoning: My CYA is 0. I need it to be about 30 for an attempt to use my IntelliChem. I happen to have a bucket of pucks, so this is more convenient than going out and buying stabilizer. My SWG is also offline since my water temp is 47 degrees, so I'm manually chlorinating right now.
Pool company inadvertently sent me a bucket of ProTeam 3" High Tech Tabs even though my pool is salt water. They look to be mostly trichlor, SDS located here: http://www.proteampoolcare.com/images/uploads/proteam_3in_high_tech_tabs_1.pdf Website with description here: ProTeam Pool Care
Website mentions that they add Borates: "Advanced borate technology, produces higher chlorine efficiency".
So here's my questions:
1.) What's the method of using pucks if I choose to move forward with this? Do I just drop one in my skimmer? How often do I do this, or do I just rely on my testing? If I'm relying on testing, is there a starting point that someone can offer based on my pool size? Here's my numbers from last night in case it helps:
3.) It seems that Borates are a good thing, but I haven't read enough. Is the fact that these pucks contain borates a reason to go down this route?
FC: 2.5
CC: 0.5
PH: 7.3
TA: 70
CH: 175
CYA: - not registering at all
Salt: 4000
2.) How many pucks will it take to raise my CYA to 30? From pool math, with an assumption of an 8 oz puck of trichlor, it would seem that it would take over 23 pucks. Depending on the answers to #1 above, this could take a really long time?CC: 0.5
PH: 7.3
TA: 70
CH: 175
Salt: 4000
