Results 1 to 8 of 8
Thread: Iron stain
    Teald024's Avatar
    Aug 2016
    Lyme, NH, formerly Columbus, Ohio
    1,488
    Iron stain
    So my opening didn't go perfect, or should I say my closing. When I pulled the cover off I found a lonely screwdriver sitting on the bottom of the pool, right under my skimmer. By the looks of the tool and vinyl liner, it was there for more than a couple of hours. So now I have this "nice" brown stain on the liner.
    I guess the easy part is that I know that it is an iron stain. Now to get it off of there.
    I found the article on metal stains and the Vitamin C / Ascorbic Acid Treatment for staining but those seem to be written to help if I have general staining, not one particular spot to treat. I get that Vitamin C / Ascorbic Acid will remove the stain, but I'm uncertain what to do next.
    The stain is about 3" long and 1/2" wide. I've vacuumed up the loose bits.
    How much Vit C / AA is needed?
    Tablets or crushed in a sock?
    Since this is only a spot treatment, I assume the FC drop isn't necessary?
    Is the sequesterant needed with this (minimal?) stain?
    Once the stain is gone off the liner do I need to do anything else?
    Is this amount of staining significant enough in 12k gallons to cause me any future problems?
    I'll try to grab a pic tonight.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Iron stain
    I would crush up tablets in a sock and use it scrub the stain away. No need for a sequestrant. It should be fine.
    30,941
    Re: Iron stain
    Welcome to the forum
    How much Vit C / AA is needed? Maybe 1/4 cup. enough to cover the stain
    Tablets or crushed in a sock? crush the vitamions and put them in a sock
    Since this is only a spot treatment, I assume the FC drop isn't necessary? correct
    Is the sequesterant needed with this (minimal?) stain? No
    Once the stain is gone off the liner do I need to do anything else? No
    Is this amount of staining significant enough in 12k gallons to cause me any future problems?No
    Teald024's Avatar
    Aug 2016
    1,488
    Re: Iron stain
    I haven't tried any removal yet, but here is a shot of the stain. Looking at it again it is about 3" long and 1" wide.
    30,941
    Re: Iron stain
    Well, that doesn't look like an iron stain to me but I think trying the vitamin C is still your first step.
    DFW, TX
    24,974
    Re: Iron stain
    I agree it looks organic. Either Vit C or chlorine will get it. More here, Pool School - Pool Stains
    Apr 2017
    Maine
    231
    Re: Iron stain
    I'd say organic and with proper chemistry it will disappear over time.
    Teald024's Avatar
    Aug 2016
    1,488
    Re: Iron stain
    Quote Originally Posted by Teald024 View Post
    When I pulled the cover off I found a lonely screwdriver sitting on the bottom of the pool, right under my skimmer..... I guess the easy part is that I know that it is an iron stain. Now to get it off of there.
    Please reread my original post.
    I fished this hunk of plastic & iron out myself with disappoint on my face . I wiped the rusty sludge off the screwdriver and there was a brown stain on the liner under it. It's definitely an iron stain. I think I'm going to wait til the water warms up a bit, it was a balmy 64F this morning. Thanks for the info about the Vit C.
