Thread: Hayward Aqua Bug - Pump Cavitation/Flow
    Sep 2016
    Central, Illinois
    71
    Hey all,
    I have a Hayward Aqua Bug pool cleaner, Every time I hook it up, My pump cavitates, it still has flow and doesn't cavitate dry, but it is starving the pump. The hoses all jump. I am sure it's because the orifice on the Aquabug is 1" Maybe, and then it goes threw a 1-1/4? hose, into a rubber cone which goes down to 1" maybe, so I'm sure that is causing restriction to be able to flow a the needed rate.
    The question is, is there anything I can do about it?
    Thanks!
    -ThaChad
    Trendium Pool Products Inc. (Vogue) - Azor 18' x 33' x 54" AGP - (15,700g)
    - Pentair Clean & Clear 150SQ/FT 1.5HP 2 Speed Cartridge Filter System (PNCC0150OF2160)
    - Hayward AquaTrol Salt Chlorine Generator (AQ-TROL-RJ)
    - Dolphin Nautilus with CleverClean
    kwss1976's Avatar
    Apr 2017
    west monroe louisiana
    13
    Re: Hayward Aqua Big - Pump Cavitation/Flow
    Mine does the same does the pump prime back up after you unhook it?
    Sep 2016
    Central, Illinois
    71
    yep.
    Sep 2016
    Central, Illinois
    71
    Re: Hayward Aqua Bug - Pump Cavitation/Flow
    So I took the little throat thing out of the bottom of the Bug and BAM! Problem Solved!
