Results 1 to 9 of 9
Thread: Is my testing method OK?
    Jordy Verrill's Avatar
    May 2016
    Cincinnati, Oh
    41
    So this might be a silly question, but it will help settle my anxiety/OCD. The way I test my water is by filling a plastic cup, which is and always has been used solely for testing water and never used to drink from or washed or anything like that, from about a foot below the surface of the water, then bringing the cup inside to do my testing. Is the water sitting in the cup, then going into the testing tube going to affect my numbers at all as opposed to just directly filling the tube from he pool?
    Like I said, probably a silly question. Just wondering if anyone else does something like this or if the experts here think this is fine.
    16x32, In Ground, ~20,000 gallons, Vinyl
    1hp Hayward Pump, Hayward s200 Sand Filter, Raypack Heater (rarely used)
    Taylor K-2006 test kit
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,268
    Re: Is my testing method OK?
    Eh, likely not. But, the cup may have some residual chemicals on it from the previous time you tested. Make sure you rinse it in between testing. Personally, I test by scooping water into whatever vessel I'm using to perform that test with, whether it be a cylinder or comparator.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Not sitting for any longer than it takes to warm to room temperature.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    This is perfectly fine. Run your pH and FC right away, and you'll be good. That goes for no matter what you get the sample in. Its always just good practice. In a lab setting you would also always rinse your sample cup, and vial three times with the test sample first, and between different sample tests using the same vials. It takes only a little bit of sample to thoroughly rinse each time. If you want to do it right, that's the way. Rinsing your glassware with distilled water after you're all through is also good practice.
    Essential Links:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    You might also consider getting a squirt bottle to take your sample from the pool in. It's very handy, and makes filling the vials very easy. Again, triple rinse the bottle with sample you grab each and every time.
    Essential Links:
    30,964
    That squirt bottle Patrick is talking about is the cat's pajamas.
    Scoop up a sample about a foot deep or so like you said, then take it inside and perform your tests.
    We are not doing Universe altering research here so don't overthink it.....we're just pool nerds (good ones, though)
    May 2016
    Cincinnati, Oh
    41
    I always rinse my my cup with water from the pool and then rinse my test vial with water from the cup before I do tests, and test right away, so I guess I'm good to go. Those squirt bottles look nice though... I might have to invest in one of those.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Those type can be found as "wash bottles." (Unitary) Nalgene is the best.
    Essential Links:
    Sfpat's Avatar
    Jul 2016
    tulsa
    113
    The squirt bottle is probably the best thing I ever got from Leslie's
    40 year old pool, 35k gal w/spa, gunite replastered July 2016, Hayward Sand filter, Hayward 1.5 hp single speed pump, TF-100, Kreepy Krauly suction side cleaner Dolphin M400
