Hello Everyone,
I'm new to TFP and would like to get some clarification on replacing my X10 PWL01 Pool/Spa light switch with an X10 WS469 switch. Both the pool and spa lights are controlled by a single switch. The old switch has only a black wire and a blue wire. The new switch has a black wire, a blue wire, a red wire and a white wire. I believe the new switch black wire and blue wire connect the same as the wires on the old switch. The red wire on the new switch is not used so it would be capped off. But I'm not sure where I connect the switch white wire. Attached are some pics of the old switch and the old switch wiring and pics of the new switch I want to install. Does the switch white wire connect to the two neutral wires that are twisted together with the red wire cap in the wiring picture?
Thanks for any help you can provide - John
