Results 1 to 7 of 7
Thread: noobie question
    Apr 2017
    Baltimore, MD
    3
    noobie question
    I bought a new house recently that has a pool, the first pool that I have owned myself. I'm a big DIYer so I've been learning how everything works and getting the pool set to open myself. After taking the filter system apart for cleaning, and installing the new water pump that the previous owners bought but never installed(? who knows) that it would have been smooth sailing.
    The problem that I ran into seems pedestrian but nonetheless has confounded me. The pool has a paramount in floor cleaning system. When I took the pool cover bag out it had a number of parts for the pool in it, one of them was the 6 port module that fits into a distributor valve for the cleaning system. For the life of me I cannot get that 6 port module to fit back into the base so I can put the top back on.
    I have tried orienting the module in every possible position. In a few of them it will drop down further than others, but never far enough for the lid to fit. When I watch the videos from paramount on troubleshooting the module it looks like it just easily drops down in there.
    I'm wondering if it is time to replace this module. When I swish it back and forth in the water the pistons are not cycling up and down. I can manually push the pistons down. They only retract to just before that lower plastic bracket. I wasn't sure if that is the problem, the pistons are stuck open and are not retracting far enough to sit down into the module base. I've tried pressing on them and they don't seem to budge. I don't want to break anything so I haven't been that rough with the thing. I haven't tried taking the module apart to see what is going on in there. I wasn't sure if it is even worth it at this point.
    Any advice would be amazing. Thanks!
    ~Mike~
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,310
    Re: noobie question
    Mike,
    Welcome to TFP.. A Great resource for all new, old pool owners...
    I own a robot and am not a big fan of in-floor systems because it forces you to use your pump to clean the pool.
    But, we have a number of members here that love their in-floor systems, so let's see if we can get one of them to chime in..
    Keep in mind that most members do not own an in-floor system, so if it takes a day or so to get an answer it isn't because we are ignoring you..
    Thanks for posting,
    Nov 2015
    Chicagoland, IL
    209
    Re: noobie question
    Following along because we have a paramount infloor system, but don't have it working because parts are missing (including modules) and it's low on our fixerupper priority list.
    In our module housing there are little plugs for each of the pipes, from when it was last winterized. Are you sure all those are removed? I'd be interested in seeing photos.
    Apr 2017
    Baltimore, MD
    3
    Re: noobie question
    Thanks for the idea! I'll take a look when I get home later. I'll definitely grab a few pictures if I can't figure it out.
    I did think there was something that looked like plugs or something that needed to be pulled out. They didn't seem to really want to move so then I thought maybe I was wrong. I've been a little gun-shy since I am not entirely familiar with these different parts yet and haven't wanted to start yanking on stuff.
    tucsontico's Avatar
    Mar 2014
    227
    Re: noobie question
    I own an in-floor cleaning system (A&A) and like it a lot! However, I also own a robot. Between the two cleaning systems my pool is nearly spotless! Anyway, post some detailed pictures of your Paramount system and I'm sure the other experts on this site will be able to help you get it back together.
    19,500 gal, 16' x 38' PebbleTec IG Pool, Built 4/2013; Pentair IntelliFlo VS 3050 3 HP Pump, Pentair Intellichlor IC40 SWG, Pentair IntellipH, Pentair 520 sq ft/150 GPM Cartridge Filter, A&A In-Floor Cleaner, Dolphin Nautilus Plus Robot (aka "Robbie"), Pentair EasyTouch Power Panel w/ Quick Touch 4 Remote Control, Autelis WiFi controller, Clear 12 mil Solar Cover on Presto SS Reel, Taylor K-2006 Test Kit.
    Apr 2017
    Baltimore, MD
    3
    Re: noobie question
    I'm still at a loss. There aren't any plugs in the main tubes. The other things look like tire valves, the middle pin depresses. I did try and remove one for the heck of it. I could take the wing nut and the washer off but the stem itself didn't seem to want to come out. I attached a picture of the module and module base.
    http://i.imgur.com/ILPjoMX.jpg
    http://i.imgur.com/lU4uYJb.jpg
    http://i.imgur.com/EQ3RFZP.jpg
    Thanks! ~Mike~
    Yuma AZ
    72
    Re: noobie question
    The plugs need to be removed prior to module installation. Water enters the system - middle pipe- then moves through each cleaning zone via module. Each time the cleaning heads retract they will turn 1/4. Module definitely will not fit with plugs inserted.
    10,000 gallons IG Freeform, 8ft raised spa,pebble finish
    FNS 60 Sqft DE Filter,2HP Whisperflow for Pool/Spa filtering
    2HP Whisperflow for Spa jets
    1HP Whisperflow for Waterfall
    Master Temp 400,000 Btu Heater
