I bought my house with just enough time to close it last fall. I haven't opened it yet but I've been anxious to see what I'm working with and to test out my fancy new test kit, so I scooped some water from under the cover yesterday and did some tests.
FC: 0
CC: not tested
PH: 7.2
TA: 90
CH: 200
CYA: 20 (or perhaps a little less)
Based on the shelves and shelves of chemicals and tri-color tabs in the pool shed, I thought I was going to be inheriting a mess. Based on this initial test, it seems I might not be that bad off.
I will retest again in a day or so to make sure I'm not screwing anything up, but the tests seemed pretty easy to follow. For my CYA test, I lost sight of the black dot just as the tube was full (above the 20 mark) so I'm thinking that I am probably a little lower than 20. Not sure how that is possible since there was a puck floating in the pool when I bought the house.
1. Since the water is stagnant (I haven't started the pump/filter yet), would that skew any of my results?
2. It seemed the CC test was part of the FC test and since my FC test was zero after the first step, I stopped adding reagents. Do I just complete that test as per the instructions to determine CC?
3. What are you all using for a thermometer? Are the cheapo floaters reliable and relatively accurate? I don't think I need wireless / digital.
FC: 0
CC: not tested
PH: 7.2
TA: 90
CH: 200
