Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: Pentair pump keeps shutting off with drain error, even though the baskets are clear
    Julz13julz's Avatar
    Apr 2017
    Dallas, TX
    70
    HELP!!
    For weeks now and actually periodically for months- 2 year old pool, my pump shuts off with error and causes the system to not circulate. I have checked for air...leaves..., water seems to fill the basket fine, but then kicks off!
    Today, I noticed that I could turn on the air blower to the spa and the cleaner, and the waterfalls, and the pump seems to stay on. Then I noticed that after shocking the pool (due to no chlorine circulation for almost a week) I got the pump to work and stay on, but the spa is yuck, and not getting any circulation!
    I hate this pool, it has never been 'no hassle' as advertised.
    I have a new Pentair Intelliflo VS + SVRS. Please help
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,248
    Re: Pentair pump keeps shutting off with drain error, even though the baskets are cle
    J,
    Welcome to TFP... A Great resource for all your new pump issues...
    This is the downside of having the SVRS option... Sigh. The pump basically thinks that something is blocking the input line to the pump and is shutting down.
    So, either the pump is bad, and since it is new should be covered under warranty, or there really is a problem with the input line.
    My guess is that you have a plumbing issue, or a plumbing design issue, but that is just a guess.
    How about providing us with a couple of pics of your equipment pad, showing the valves on the input side to the pump and another showing the whole pad.
    When was the last time you cleaned your filter?
    What is your current filter pressure?
    What color is your water?
    Does your pool have an automation system?
    How do you currently chlorinate your pool?
    Thanks for posting and looking forward to your answers,
    Julz13julz's Avatar
    Apr 2017
    Dallas, TX
    70
    See answers below
    Unfortunately our Pool builder is a jerk and doesn't return phone calls because the large $150k large pool/ patio job had many other small issues that he was tired of dealing with.
    This is te first time that the spa is not circulating. The pump has done this many times (but never for this long) and somehow I always get it to work for a while.
    How do I post photos?? (I'm on mobile version)
    I will take photos tomorrow of the equipment/ valves.
    3 wks ago
    About 40
    (The dial is in 'clean filter' range). But we had a pool guy come and clean it about 3 wks ago.
    I never have opened the filter thing- have always paid a service to do it. And I wasn't here when they did.
    It was cloudy blue/green
    Spa is now bright cloudy blue.
    Yes
    Auto Chlorinator with stacked tablets.
    But since no circulation recently, I put in 2 scoops of chlorine granules and almost gallon of acid. (The chlorine test showed almost no chlorine prior)
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    570
    40 PSI is high for filter pressure. Filter may be clogged up with that blue muck or algae. You may need to shock you pool with liquid shock to clear the water and the filter.
    Is it possible that you could be low on water as for the pumps can sometimes suck more from a skimmer when the water is low and get air in the pump and that shuts it off.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Julz13julz's Avatar
    Apr 2017
    Dallas, TX
    70
    I thought that was high too
    But I'm newby and can do things if there is a knob or handle, but big wrench thing- scares me! Lol
    Water is full and I even added water to the spa.
    Do you find it odd that when I turned on the 'air' to the spa, that I was able to keep the pump on?
    Now the pump has been running all day, and it is spa that is still, motionless.
    Btw: once I turned the cleaner off and air off, the pump shuts off again. But now with the cleaner on- it will stay on...
    Does any of this make sense?
    Julz13julz's Avatar
    Apr 2017
    Dallas, TX
    70
    21,000 gallons (pool and spa), IG, pebble tec, pentair clean&clear plus CCP520, pentair Master Temp 400 heater, Pentair model 320 Rainbow auto chlorine inline feeder, built in 2016. TF-100 test kit
    Jul 2014
    Bedford, TX
    9,248
    Julz,
    Ok... Based upon your answers here is what I think..
    You have been using 3" chlorine tablets which have over a period of time has increased the CYA level in your pool to a point that a normal amount of chlorine will no longer prevent algae.
    The reason your water is not clear is because of the algae and this same algae is what is quickly clogging your filter.
    With the filter clogged, the weak flow through the pump causes it to go into the SVRS safety mode and shut off.
    Sorry, but I have more questions..
    1. What type of filter do you have?
    2. Can you please post a couple of pics of your equipment pad?
    Julz13julz's Avatar
    Apr 2017
    Dallas, TX
    70
    Julz13julz's Avatar
    Apr 2017
    Dallas, TX
    70
    Julz13julz's Avatar
    Apr 2017
    Dallas, TX
    70
    If I reset the system at the panel- then turn on the cleaner, then go to the small 'pool pump' panel and hit reset...
    Then the pump (and eventually cleaner) will come on, which is why the pool looks a lot better!!!! As you can see in pic, but the spa is still not circulating- thus cloudy and blue.
    During the summer we put the granules into the pool in addition to the tabs- but didn't over the winter, as the pool co said only needed when hot/ sunny.
    Questions:
    Why isn't the spa circulating?
    Why do I need the cleaner on to keep the pump on?
    The spring 'fall' caused a lot of leaves and debris, but after that, I had pool guy clean/ chemicals (3x in march), and clean filter also.
    Ughhh
    Julz13julz's Avatar
    Apr 2017
    Dallas, TX
    70
    Also, the chlorine level, I believe was so low to begin with, because the pump had not been circulating for a week, and I did. It know it, until the pool looked horrible.
    Jul 2014
    Bedford, TX
    9,248
    Julz,
    I have to head to a doctor's appointment this morning.. Will get back with you later today..
    Let's see if we can get some of our other members to chime in here..
    Jul 2011
    St. Paul, MN
    244
    Hi Julz,
    Please read this to learn how to get and maintain an algae free pool. As Jim mentions, having a clean pool will likely solve your pump problem:
    Pool School - SLAM - Shock Level And Maintain
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    Jul 2014
    Bedford, TX
    9,248
    Julz,
    More questions and something you can try..
    1. Does your spa "normally" overflow into your pool?
    2. I assume you have an EasyTouch Automation system. If so, do you also have the ScreenLogic system to control things via your PC or phone?
    3. I see you have the Intelliflo pump (a great pump). Do you know what speed it is running when the filter is at 35 to 40 PSI?
    So, looking at your pics it appears to me your valves are in the Pool position with the Spa shut off. These are the two automated valves..
    Please try pushing the "V" button and selecting the Spa mode.. I'm interested if both automated valves turn about 180 degrees from their current position.
    Then push it once more and see if it goes into the "spillover" mode.. (It may not..) If it does water should overflow into the pool.
    Then pushing it again should return it to its current position.
    I'm just trying to confirm the automated valves are working.
    I still think the main problem is a clogged filter.
    Julz13julz's Avatar
    Apr 2017
    Dallas, TX
    70
    Hi.
    Yes I have the easy touch, but not the phone capabilities (that I know of).
    It does often overflow, but honestly don't know if it does all the time.
    Yes, I have hit the V button yesterday while trying to find anything that would help, and the valves moved 180, then back again when I hit again.
    But... for spa mode, the pump doesn't work. The pump shuts off, like usual.
    The spillover mode didn't work either, as nothing flowed through spa.
    I agree
    Question is:
    If the filter is clogged, and the guy did clean it as he said he did in March, what could possibly make it clogged again? Those leaves/ tree droppings in March?
    Also, I'm sorry but what is cya?
    (In my business it means something else. )
    And why are the chlorine tabs not enough?
    I don't have any idea what the speeds are set at. They set it
    When installed.
    Is that why the pump works when cleaner is on, Because it runs at higher speed...
    Julz13julz's Avatar
    Apr 2017
    Dallas, TX
    70
    Also, any indication, by looking at the valves, why the spa isn't working when I do actually get the pump to work when cleaner is on?
    Julz13julz's Avatar
    Apr 2017
    Dallas, TX
    70
    Ok
    Bottom line
    I'm not mechanical and a little scared of the bolts and different tools, but I will search my filter and find the steps to clean it. ..
    Julz13julz's Avatar
    Apr 2017
    Dallas, TX
    70
    Update!
    I did it- the filter is clean and it started up like a lion !
    Thank you!! Now look at the spa!!
    Good job. The pressure at 35 was definitely a problem. That's pretty much maxed out for that pump.
    The filter must have been really bad.
    The pump is probably running too fast most of the time.
    Support the site
  20. Back To Top    #20
    Julz13julz's Avatar
    Apr 2017
    Dallas, TX
    70
    Do you think it running to high?
