Thread: Concrete deck resurfacing issue
    Jul 2016
    Gainesville, FL
    127
    I tried Behr textured Deckover, which is supposed to last two coats 75 sq ft per gallon. It only lasted about 20 sq ft. My deck is very porous:
    after application:
    Any ideas how to do this without spending tens of gallons of product?
    Inground 28000 gal Concrete, Hayward Progrid DE filter 6020, US motors 1.5hp pump (3450rpm) , Polaris 360
    600 gal hot tub, Spa Vita, Nature2+MPS
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,968
    Re: Concrete deck resurfacing issue
    I worry if you put something over the current decking the other one will not stick to it With you already starting you are between a rock and a hard place.
    Kim
    Jul 2016
    Gainesville, FL
    127
    Quote Originally Posted by kimkats View Post
    Kim
    why would it not stick?
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,344
    What did you use to apply the Behr deckover?
    Suz~Cypress/Houston area~ My 2015 Pool Build. 24K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy; color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. TF-100, SpeedStir
    Jul 2012
    Tallahassee, FL
    33,968
    I worry the other stuff would be too slick for the good stuff to stick to. You can do an experiment. Put some sealer on a rock or something like your patio then put the good stuff over it. Let it all dry good and see if it does stick.
    Kim
    Jul 2016
    Gainesville, FL
    127
    Quote Originally Posted by SuzfromTexas View Post
    1/2" nap roller. Stuff is so thick I had to pour it directly on the surface and spread with the roller
