Thread: Would appreciate replacement pump reccomendatiopns
    May 2014
    Hampton Falls, NH
    5
    Hi,
    After many fixes, seal replacement etc my pump has finally given up the fight . I would appreciate any recommendations for a replacement.
    Here are the specs on my current equipment including the pump name and number. Jacuzzi Magnum 1HP model # 94027110
    10,000 +/- gallon IG Vinyl Pool, Jacuzzi Sand Filter (model 190L)16,800 gallons/6 hours, Jacuzzi Magnum 1HP pump (model 94027110), Raypak Versa Pool Heater (model 155C)
    Many thanks,
    Bern
    Thank you,
    Bern
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Would appreciate replacement pump reccomendatiopns
    I would go with a 1hp 2 speed Pentair Superflo or Hayward Maxflo pump and run it on low most of the time. You'll save about 75% off your electric bill. If you ware interested in a variable speed pump they both make a 1-1/2hp VS pump.
    Apr 2017
    Californoa
    25
    Jacuzzi has new pumps on the market if you want to stick with the same brand. Otherwise the pentair 1.5hp vsp superflo or 3hp pentair vsp intelliflo
