Thread: I need a replacement drain cover for my spa ...
    DeanP66's Avatar
    Mar 2014
    San Jose, CA
    703
    So, I was inside my spa with the water 90% drained, trying to clean the horrible calcium buildup I had on the tile. Long story short, I wasn't paying close enough attention and accidently put my heal through the spa drain, breaking it into about 20 pieces.
    This is an old Anthony Pool from the late 60s or early 70s that had the old flush drains in both the spa and deep end of the pool. I know newly built pools are required to use the newer style safety drains. My question is can I use one like I already have or do they not even make those anymore?
    If not, anyone have any idea which one would fit my pool's drain?
    Here are a couple of pics of my drains:
    Pool size: 20,000 Gallon Plaster Pool, Pump: Hayward Tristar VS SP3202VSP, Filter: Pentair Clean and Clear Plus 320
    Polaris 280 Pressure side cleaner, Solar cover, Pentair Amerilite LED pool light, Taylor K-2006C test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: I need a replacement drain cover for my spa ...
    Inyo Pools has a drain cover for you.
    DeanP66's Avatar
    Mar 2014
    San Jose, CA
    703
    Thanks pooldv, I'll check them out.
    DFW, TX
    24,974
    They will sell you a VGB compliant drain cover that is domed to avoid suction entrapment onto the drain. The old flat covers are no longer available for sale.
