Results 1 to 7 of 7
Thread: Electrical problems
    hot tub saxophonist's Avatar
    Apr 2017
    Dallas, Texas
    2
    Electrical problems
    Just closed on a home with a beautiful IG pool. I'm a DYI guy, but my knowledge is limited on pools as this is my first. Okay, pool inspector did a walk through with me and there are 3 electrical problems:
    1. Bonding wire not connected to inlet pump, heater, or spa blower
    2. External time clock is wired to Pentair Intelliflo pump. He said this is not necessary since the pump has its own internal clock and that this setup will shorten the life of the pump.
    3. GFIC receptacle has reversed polarity (I think I can figure that one out).
    I am attaching a picture of my equipment. I'm having trouble uploading pictures, so more to follow. Thanks in advance for any advice!
    David
    18K gallon IG with spa, pebble, Pentair Intelliflo VS pump, Pentair FNS Plus 60 DE filter, Letro cleaner pump, Rainbow 320 inline chlorinator, Rheem gas heater, Polaris 380 pool cleaner, city water
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Electrical problems
    If anything on the equipment pad is bonded you can just extend the bond wire from there. Inside the time clock move the wires going to the pump from the switched side to the load side.
    It is important to note that bonding is different from grounding. More here, Pool School - Bonding vs Grounding
    Paul & Crystal's Avatar
    May 2014
    Oklahoma City, OK
    539
    Hi...here's some more pics of Hot Tub's set up...
    60K 53 X 23 X 3'-10' IG Grecian Concrete aka "The Beast"
    TF100 XL with Speed Stir
    Dolphin M500 aka "The Beast Master"
    Sta Rite Max E Pro 2 HP - Hayward Pro Series Sand Filter S310T.
    My Pool Thread: Old School Pool
    May 2014
    Oklahoma City, OK
    539
    Danny...would you look through these pics and tell about the puck feeder. It says chlorine and bromine...so is it just for the hot tub or is it for the pool too? Last night his FC was 3 and CYA 100...so pool math said add 230 0z to get to 13...but this morn his FC is 18....18k gallon pool....looks like it needs some water though. So either it is getting fed chlorine through a feeder or the volume is off?
    Thanks!
    May 2014
    Oklahoma City, OK
    539
    Danny...also...I was telling him about using just chlorine in the hot tub...I'm thinking I saw that you are running that way?
    If so...please explain benefits and basics? Point him to info threads plz!
    Crystal
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,975
    That is such a pretty pool and area! No wonder you bought it!
    Thanks for setting up your signature! Hummmm I wonder who has been in your ears LOL
    Puck feeder-turn everything off. Open up the top and see what is in there. Use care with your face as there might be some chlorine fumes that may come up to say hi. For right now leave what is in there in there until we get you all sorted out.
    Here is a link to using chlorine in a spa:
    How do I use Chlorine in my Spa (or pool)?)
    I am so glad you are here and have started a thread!
    Kim
    DFW, TX
    24,974
    There are chlorine pucks and bromine pucks and it can do either. But, they cannot be mixed, it has to be one or the other. And bromine isnt the best option for anything outdoor because it cannot be protected from the sun like CYA can protect chlorine. That equipment looks to serve the pool and spa. So, best to just manage the pool and mix the water together periodically via the spillover. Then if you can close the pool and leave the spa open for winter then you can manage it more like a spa using this process, How do I use Chlorine in my Spa (or pool)?
