Thread: Pucks while away, will I be ok?
    Mar 2017
    Rayne, La
    1
    New owner of an old pool and this is my first post here. I think I get this whole trouble free pool thing. It all makes since to me. My one major issue is the number of times I will be away from my pool for several days to a week at a time this summer. Do I just let mc FC levels fall while away and deal with the results when I get back? Do I throw a couple Chlorine pucks in the chlorinator while I'm gone and deal with the results when I get back? How do you guys/gals handle this situation?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Pucks while away, will I be ok?
    Welcome to TFP!
    First thing to do is raise the FC level up to shock level for your CYA, FC/CYA Chart. Then if that won't be enough to last until you return you can float a puck or two in a floater in the pool or in the puckinator.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,895
    Or, upgrade to some form of chlorine automation - SWCG or Stenner Pump
    Support the site
    Jun 2016
    Martinez, CA
    241
    I have an inline rainbow puck feeder that normally stays out of service. When leaving for any extended time, I raise FC level and utilize the puck feeder to keep a minimum safe FC level,while Im gone. It add some amount of CYA but not enough to make it an issue. These feeders are ~$60 and easy to install.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
