Results 1 to 7 of 7
Thread: FIlter
    Apr 2015
    Waukesha, Wi
    27
    FIlter
    I had an intex easy set pool 18 x 48. Want to upgrade to an 18 x 52 hard side pool. My question is: can I use the filter system that came with the intex which is 1500 gpm on the new hardside
    pool. I also have the intex salt water system attached to the filter. Can I use them both on the new pool?
    domct203's Avatar
    Jun 2015
    CT
    3,915
    Re: FIlter
    Quote Originally Posted by Ernap01 View Post
    I had the Intex 2500 GPM sandfilter on my 18' X 48" Ultraframe and felt that it was undersized for that pool.
    I recommend you invest in a larger filter and pump.
    What size is the SWG? The 15K gallon unit is the smallest I would use.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    30,964
    Re: FIlter
    Intex filters and pumps are ALWAYS undersized and inadequate. I would not use them.
    Intex marketing plan is to sell you markedly inferior pumps and filters so you can buy larger ones (from intex) when you discover the problem.
    Apr 2015
    Waukesha, Wi
    27
    Re: FIlter
    Can you leave an Ultra frame up all winter? I live in wisconsin
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,753
    Re: FIlter
    I live much farther south than you, but we have had some hard freezes. I have left mine up over the past 3 winters with no problems. I do of course disconnect all hoses and drain below the skimmer before I cover it.
    It's my opinion that they are more likely to receive damage from folding them up and storing them than they are from freezing.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Apr 2015
    Waukesha, Wi
    27
    Re: FIlter
    Quote Originally Posted by domct203 View Post
    The SWG is the ECO 8110 which I believe is for pools up to 15,000 gal.
    domct203's Avatar
    Jun 2015
    CT
    3,915
    Re: FIlter
    I live in CT, I've left mine up the past two winters.
    Dom - TFP Guide
