Thread: Sand Filter questions: issues with pressure?
    Apr 2017
    dublin
    4
    Hi,
    I have a sand based filter, when I switch the spider gasket to backwash mode, I only see dirt in the sight glass when the waste pipe is open, is this normal?
    Also, I notice that when in filter mode, the filter jets start off strong, and eventually end up very weak after about 20 minutes. When this happens the pressure gauge increases until 1.5 bar, and stays there, is something wrong?
    22,701
    Re: Sand Filter questions: issues with pressure?
    If you have a separate block valve on the waste pipe, then you won't see any dirt in the sight glass when it's closed. The sight glass is in a side stream off the waste stream and there's no flow through it unless there's flow through the waste piping. It will fill with water, but there's no flow through it.
    What does your water look like? Clear, cloudy, green, etc.?
    It sounds like you have algae growing and it's clogging the filter pretty quickly.
    Apr 2017
    dublin
    4
    The water is clear, however the bottom of the pool has lots of small dirt which has accumulated over the winter, perhaps that is clogging up the filter?
    When i was backwashing I still saw small black particles in the sight glass, even after about 3 minutes, should I continue backwashing until these disappear?
    Also, when backwashing with the waste pipe open, the pool drains, I guess this is correct?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    Welcome!
    It sounds like you could be in need of a good deep cleaning.
    Here's a tutorial on the subject:Deep Cleaning a Sand Filter
    Please post any questions you may have.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Apr 2017
    dublin
    4
    Thanks! 2 questions
    22,701
    When you backwash you should run it until the sightglass runs clear. Now, does it have to be perfectly clear of every little spec, No. Mostly clear will usually do. It's your preference on how clear you like to see it.
    Backwashing a sand filter removes water from the pool and flushes it out the waste pipe. That's how it rids the filter of dirt.
