Results 1 to 16 of 16
Thread: New Intex Pool Setup Tips?
    Apr 2014
    New jersey
    3
    Ive had an intex ultra frame pool and the legs and t-joints rusted and rotted. I just bought a new intex ultra frame 20ft round pool that i intend to leave up all year and hopefully have for a few years. Is there any info regarding what steps to take with a brand new pool set-up to prevent the rusting and rotting again? Repaint all the metal parts? Spray something? I know the finish will start to scrape away just by putting it together but im trying to figure out how to prep the pieces before it goes up. Thanks
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    Re: New Intex Pool Setup Tips?
    I'd recommend if you are using a saltwater system to stop using it. I have heard countless stories and know of many people that have had their intex frame rust because they were using a saltwater system. That would save you from the rust in my opinion anyways
    Mike
    Intex ultra frame 26'x52" above ground pool
    Intex ultra 18'x46" above ground pool retired
    jmcdtucson's Avatar
    Jun 2014
    332
    Maybe I'm missing something, but I've never heard of an Intex frame rusting because of saltwater. This is my 3rd year with Intex and SWG and no rust at all. Of course our humidity is about 0% most of the time in Arizona.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Agreed, we had an Intex Ultra frame with SWG set up for a couple of years and it was fine when we took it apart and sold it.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    No trouble with my Intex and SWG. Starting on year 4 with it.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    domct203's Avatar
    Jun 2015
    CT
    3,890
    I don't understand where stories like this come from.
    After a few years, all chlorine pools contain salt, added from the chlorine, muriatic acid, and human sweat.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    Yeah, the salt content in a saltwater pool is about the same as human tears. Nowhere near that of saltwater, which I will agree is corrosive.
    Pentair IC40 SWG
    DFW, TX
    24,974
    Actually, it is lower than human tears. Saltwater pools are around 3400 ppm, tears are 9000 ppm and ocean water is 35,000 ppm. And just for fun, the dead sea is 330,000 ppm.
    Now that we've addressed the saltwater/rust myth for the umpteenth time, getting back to the OP's original question, I'm wondering if anybody has any good ideas, also. I'm getting ready to set up a new Ultra frame and was considering different strategies to beat the rusting around some of the feet from standing water after rains. I had considered coating the inside of the legs with truck bed liner prior to installation, then coating the legs a few inches above the feet after setup. The idea being to seal around the leg and foot caps so no water could get in. I know the foot caps have a hole in them for drainage, hence coating inside the leg prior to setup.
    The truck bed liner is sold in quart cans at Lowe's. I've used it in some wooden drawers in my outdoor grill area and has worked like a charm for that. Anyone see any negatives to this?
    domct203's Avatar
    Jun 2015
    CT
    3,890
    Quote Originally Posted by Smolder View Post
    We obviously haven't addressed it enough as it keeps coming up, but I digress......
    If the insides of the legs are not painted it would not hurt to paint them. I think the biggest issue is that the pool moves when in use, which scrapes away the paint inside of all the connections. While painting the inside of the legs would help with rust there, I don't know what can be done to prevent rust inside the connections.
    Dom - TFP Guide
    Jun 2015
    Eastern Nebraska
    15
    I'm in the same boat. Getting ready to set up a 26' Ultra Frame that I intend to leave up. I was thinking about Rust-Oleum primer followed by enamel.
    The truck bed liner material is intriguing.
    16,000 Gallon, AG Intex Ultra Frame, Intex 3000 Sand Filter System, Intex SWG, Taylor K-2006 FAS-DPD
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    I considered sealing mine off at the joints with a flexible silicone sealant, because my last pool rusted out. But I never did, and this pool is starting year 4 with only minimal rust so far.
    The liner has faded pretty badly, so I'll probably replace it after this season anyway.
    Pentair IC40 SWG
    Yeah, same with my pool. 4 years, minimal rust, very faded liner. Want to make some adjustments with the pavers, put the anti fatigue mats under pool, hard plumb and add the hayward skimmer in the side wall. I figured if I was going to make all these changes, i would start fresh with a new pool. Intex has made some design changes to the pool since I bought my last one. The horizontal beam brackets are moulded plastic now. It looks like it will minimize rust on those parts with no metal to metal contact.
    Apr 2014
    New jersey
    3
    What was the goal in delegitimizing the existence of rust and corrosion? If you haven't experienced it then why comment? It's obviously an issue. My prior intex ultra frame was taken down once and stayed up through the winter once. So at the end of season #3, i could take down the pool and snap the t joints just my pulling on them. I guess the powder coating doesn't mean anything if these pieces are moved and scraped. Anyway, being that the finish is already glossy and powder coated, what would actually adhere to it?
    May 2017
    Cochran, ga
    1
    For whats its worth.... I too am in the process of setting up an intex 22'x52" with SWG. So after tons of reading I went ahead and coated the inside of all of the frame pieces with 2 coats of glossy rustoleum. I intend to leave it up (in GA with tons of humidity). So, I dont want to take any chances.
    I don't think anyone was arguing the fact that rust/corrosion will occur, just that the saltwater was the culprit. The point of the post is how to minimize the affected areas where the metal to metal contact will deteriorate the finish. In answer to your painting question, the truck bed liner will stick to anything, it's basically tar. Any area you want to paint with a rustoleum type of finish would need to be lightly sanded prior to painting. Although the inside of the legs don't have any finish to start with, so no need there.
    Quote Originally Posted by Vinnyd77 View Post
