Thread: Solar pool heater Tampa FL
    Apr 2017
    Tampa FL
    2
    So I'm sure everyone here is much more in formed on this subject than me. Friend gave me these panels we are going to hook them up on our roof at a very slight angle. And I have a couple of questions.
    1. They were hooked together with rubber hose previously what type is the best ?
    2. Was going to place two ball valves in the system is there anything else that should be placed / reccomended. Pressure valve? Thermostat?
    3. Are these types of solar heaters common see much more of the plastic ones not welded aluminum like these?
    Thanks Justin
    IMG 0176 — imgbb.com
    IMG 0177 — imgbb.com
    Apr 2017
    Tampa FL
    2
    Re: Solar pool heater Tampa FL
    Guess my most important question is the tubing to connect the panels to each other was thinking radiator hose ?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
    Here is a nice install guide that I used to install my panels. There are also pics of my solar install in my pool thread, link in sig.
