Results 1 to 8 of 8
Thread: How do I read salt strips properly?
    Apr 2015
    Marietta GA
    85
    Here is my salt strip... do I read this as 5.2 or 6.0?
    Type: IG Vynal
    Size: ~ 22,000 GAL
    Filter: Sand - Hayward S244T Pro Series w/ 1HP Hayward Pump
    Saturn94's Avatar
    Mar 2015
    Virginia
    553
    Re: How do I read salt strips properly?
    I would read it as 6.2.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 w/booster pump/Hayward Superpump 1 hp/city water/Taylor test kits/pool installed March 2004
    Apr 2015
    Marietta GA
    85
    Dang, that means the reading on my aquarite is about 1000 off... it shows 1600 on the display. Maybe it will be more accurate in the morning. I just installed it today, I'm sure it needs more than a few hours to adapt.
    Type: IG Vynal
    Size: ~ 22,000 GAL
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Looks like 6.4 to me.
    Apr 2015
    Marietta GA
    85
    I just noticed that someone on my previous thread told me to leave the salt system off for a day or two while everything mixes properly. I think the vast majority of the salt has dissolved based on the test strips and what I could see earlier.
    I turned Wanda (Zodiac MX-6) lose on the new salt earlier today and watched it all dissolve in the leaf canister.
    Type: IG Vynal
    Size: ~ 22,000 GAL
    JoyfulNoise's Avatar
    May 2015
    14,083
    6.4
    Did you submerge the strip in 1" of water only? It matters. Temperature matters too with strips; the water should be room temperature.
    This shows one of the many reasons why strips are inferior to the drop based titration test (K-1766) - it's too easy to misinterpret the results.
    I suggest you get the k-1766.
    Matt
    Apr 2015
    Marietta GA
    85
    6.4
    I will order the kit.
    I used the PH chamber of my test kit, it had an inch, maybe 1.5 inches.
    Type: IG Vynal
    Size: ~ 22,000 GAL
    What cell do you have?
    Is the box set to the correct cell type?
    Support the site
