Results 1 to 15 of 15
Thread: CYA whats going on R 0013
    Jun 2015
    Rocklin Ca
    79
    I've been bringing my CYA level up A couple days ago I was about under 40 so I added some CYA today I was at about 35 we did have a little rain. So my R-0013 was empty so I opened a new one maybe a year old, did another test reads “0” CYA. I did about 3 tests still “0”. I did have some old test strips it they show CYA but low. There no way it can be “0” you think the R-0013 is bad? That’s all can think of .
    In ground 20,000gal - pebble-tec - salt, Intelliflo pump, Sta-Rite filter 450 sq ft ,Hayward 6060 booster pump, non functioning Aqua Rite SWCG, TF 100 test kit.
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    Re: CYA whats going on R 0013
    What is the date on your r-0013?
    7000k Viking fiberglass Bermuda, Sand filter w/glass, Pentair SuperfloVS, Pentair IC20 swg
    Raypak 106k, Dolphin s-200, Taylor k-2006c, Taylor k-1766, Speedstir, Little Giant cover pump.
    Jun 2015
    Rocklin Ca
    79
    there is no date on the bottle my guess would 7 to 9 months
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Are there any numbers at all? Even a weird looking code?
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2015
    Rocklin Ca
    79
    No numbers, dates both labels are identical. should there be a date?
    JoyfulNoise's Avatar
    May 2015
    14,094
    2 years ago Taylor started printed expiration dates on the bottle labels. Prior to that, there was only a Lot ID # which was typically a letter followed by a few numbers.
    If your R-0013 label has NOTHING on it, then it is either not a Taylor reagent OR it is much older than 2-3 years. Either way, toss and buy a new one.
    Matt
    Jun 2015
    Rocklin Ca
    79
    It's definatly less than a year old I bought from TFtestkits, I'll just send for another, while I'm waiting I'll remove the top and let it breath like a fine bottle of wine and give it one more try.
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,268
    Hey SacDave, email me at tftestkits@gmail.com and I can send you out some new R-0013.
    30,956
    R-0013 really doesn't go "bad". At least, not in the time you have had it. How was it stored?
    Please report back what happens when you get your new bottle. Letting it "breath" is pointless.
    Jun 2015
    Rocklin Ca
    79
    I sent for some already and few other things last night. You will see the order Rocklin Ca. 95765. It's no big deal. buying the TF-100 test kit and following this forum I'm money ahead and have a really clean nice looking pool.
    Jun 2015
    Rocklin Ca
    79
    Letting breath was a joke
    30,956
    Yeah, I should've recognized that.....sorry. As you probably know, I have some skin in the game and ANY test kit issues really get my attention.
    The process by which that R-0013 is bottled makes it virtually impossible for anything but R-0013 to be in there so I am baffled as to what went wrong. I am very interested to see the result when OTPirate gets you the new bottle. Keep us posted.
    Jun 2015
    Rocklin Ca
    79
    I did test it again same results It was stored in a garage cabinet and dose get hot in Rocklin ( sacramento area) so maybe it got over heated, but the old R-0013 was in the same cabinet. Just one of those thing BTW I buy all my test supplies from TF Test kits and will continue to great company. I will post result as soon as new R-0013 arrives……………If I get a zero reading I have a problem I've put about 6lbs of stabilizer in the last 3 weeks I was at about 38 (goal is 45) should be at 45 now will see. Thanks for all the help and clean pool
    Jun 2015
    Rocklin Ca
    79
    OK got the new R-0013 today it seems to work fine reading 34 (will add CYA) I guess the the one I opened was just bad for some reason.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Steve, the Cya test resolution is 10-15 PPM at the absolute best it could ever be. If you are seeing "35" you could say 40.
    It just isn't that precise, and really doesn't need to be.
    Glad you got the new batch sorted, but can't explain what happened.
    Essential Links:
