Results 1 to 18 of 18
Thread: What do you get when pool nerd meets solar nerd?
    May 2016
    Woodland, Ca
    235
    I was was looking to build a structure over my equipment pad mostly to keep my Stenner pump out of blazing Sacramento afternoon sun. I've seen the video where they guy from Arizona rigged up a few panels, but it felt kind of amateurish so I went with two solarworld 295 panels and enphase micro inverters in order to match what's on my roof.
    Build Video 2016 -- Solar Pad 20.5K gunite (37'x15') rectangle (3.5'-7') deep-- MicroFusion Laguna finish -- Jandy VS pump, cartridge and iAqualink RS -- Polaris 360 Black -- 2 Laminar jets -- 2 nichless 30w color led -- 550sq/ft Heliocol solar -- Soft water auto fill -- Stenner 17gpd
    BattleOfYakima's Avatar
    Apr 2016
    Central Florida
    1,667
    Re: What do you get when pool nerd meets solar nerd?
    Very, very cool! What an awesome setup! Is your bleach tank the dark blue in the corner? How many gallons? So neat to see such a robust setup with room to work but also so compact.
    If I was effective, and your pool makes you smile, please make me smile and CLICK HERE to Become a TFP Supporter!
    Also, please make AmazonSmile donate to TFP by CLICKING HERE, at no cost to you!
    My Florida Pool: 20k IG plaster cart K-2006 | Washington State Pool I help with: 17k AG vinyl sand TF-100
    May 2016
    Woodland, Ca
    235
    Quote Originally Posted by BattleOfYakima View Post
    Thanks for the kind words, the Chlorine is in a Stenner 7.5 gallon container. I keep toying with the idea of a SWG, then using the stenner pump to dose acid.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Yep! Nice set up! I like it!
    Aug 2016
    Manorville, NY
    68
    Real nice set up I was starting to plan out building an extended roof off my shed to cover the pool equipment but I think you've inspired me to expand my houses solar energy and throw some panels on the roof and use some more as a roof over my pool equipment! Very cool.
    30,600 gallon SW Liner IG, 26'x46', 8' deep end, Hayward Cartridge Filter (Model C4030), Aquacal Heat Pump (Model R410A) with Autopilot PPC1 Salt Cell, Hayward Max-Flo VS (x2, 1 for pool, 1 for waterfall), Autopilot Salt Chlorine Generator (Pool Pilot Digital Model 75003), Hayward Colorlogic x3, AquaClean Robot, and SolarBreeze NX, TF-100 Test Kit
    Jun 2015
    Ottawa/Ontario
    357
    What do you use the PV power for?
    20000 gallon, Vinyl liner IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    May 2016
    Woodland, Ca
    235
    Quote Originally Posted by tlevy View Post
    Thanks for the positive comments.
    The panels are grid tied so they push power back to the grid. I run our pool pump anywhere from 400 to 800 watts so these two panels provide enough power each sunny day to run the pump for about 4 hours of skimming or two hours of cleaning. The panels don't have an ideal angle so they are only half as productive as the other panels on the roof, but they will still pay for themselves in 6-7 years.
    Jun 2015
    Ottawa/Ontario
    357
    Do you manage to run the pump directly from the panels through the inverter though? What happens if a cloud passes over and the voltage from the panels drops?
    May 2016
    Woodland, Ca
    235
    No, the pump is not powered directly by the panels.
    The pump is grid powered, so it always runs as programmed if it is sunny or not. The panels send energy to the "grid" when they produce electricity. As an example, if the pump is using 800watts and the panels are producing 500 watts, then 300 watts are being used from the power company's "grid." Another example would be if the pump is using 400 watts and the panels are producing 500watts, then the extra 100watts are sent back to the power company's "grid." I then get credited for the excess and can use it later as in the first example.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Looks good, If they are facing south I suspect they are near optimal tilt solar angle for the spring / summer swim season see Optimum Tilt of Solar Panels Another thing to remember is optimal average annual solar tilt is not always the best solution for a given problem, for example I have a 100 watt solar panel powering a remote wifi gate camera with a deep cycle battery, the panel is mount at 45 degrees which is approximately our optimal winter panel angle, as a result the panel will under preform on those long summer days, but this does not matter as it will still provide a surplus of power. Where in the winter with less available solar and more cloudy days it needs maximum optimaization.
    May 2016
    Woodland, Ca
    235
    That's a good example and I believe often overlooked factor in solar design. I've "traded" half of my potential production for the shelter aspect these panels provide. They are a few degrees south of west facing and are shaded for the first half of the day. They only produce half of what my other panels produce but $.39 kWh tier three energy makes the $$ work.
    Jun 2015
    Ottawa/Ontario
    357
    Love it . Very cool captain. Kudos to you.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,496
    Great idea! Might be past my time, but someday I think major house surfaces will be integrated PV and structural material, just like that. Great to see
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,153
    Elon's solar shingles are to be introduced soon. Won't be cheap I'm sure, but they attractive looking and have to make at least some financial sense I expect.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2016
    Woodland, Ca
    235
    Hopefully they get some of that Elon magic and they do better than then the Dow Corning roof tiles from a few years ago. I would be concerned about the current political climate in respect to the incentives that he heavily relies on.
    I would love love to see some sort of multi-stage paint that could be used to capture energy.
    Aug 2016
    Riverside, CA
    378
    Quote Originally Posted by CaptainCannonball View Post
    I have a 8.9kva system (33 SolarWorld 270watt panels as seen in the picture in the post here) on my roof with enphase microinverters. I get the read out of the whole system in MyEnlighten but am wondering how you pulled the readout of just these panels. I can log into the envoy via its local ip address but haven't really looked at it too much but is this where you pulled that graph from? As far as angle goes, my roof is 4:12 so it is 18ish degrees but our latitude is 33 degrees. Not optimum but the best you can do on the roof because to try to tilt them more they end up shading each other somewhat so it is better to just lay them flat. We're fortunate to have the house oriented a few degrees east of south though so that helps. We will hit transformer clipping for a few hours on a few days in April each year, proving that using 215watt microinverters on 270watt panels is a cost-effective approach because the minute extra power produced will never recover the additional cost of larger microinverters.
    May 2016
    Woodland, Ca
    235
    Quote Originally Posted by Sammy2 View Post
    I paid for the Enlighten Manager software (total ripoff btw) that I share with a few neighbors. It allows for individual panel monitoring and the ability to run some interesting reports. My neighbor had a golf ball strike that damaged one of his panels and he would have never known without individual panel monitoring. I mean, the panel was producing at 25% capacity so when a large system is down 150watts who would notice?
    It sounds like you have a nice system! Let's hope Enphase and Solarworld stay in business.
    Aug 2016
    Riverside, CA
    378
    I didn't realize there was even other software available.
