Thread: Overnight chlorine test + UV light
    Feb 2017
    Pennsylvania
    5
    I was lax a couple of days in giving the daily Clorox to my indoor swim spa. I noticed yesterday that my pool water appeared more cloudy. I raised my FC to 10 ppm just before sleeping (CYA at 20). In the morning my FC reading was 6 ppm. The guidelines only allow no more than a 1 ppm drop overnight. However, I have a UV light. UV light may possible accerelate the degradation of chlorine. Should I still use the 1 ppm guideline if I have UV light? Thanks.
    indoor 7x12 Endless pool (2500 gallons)
    vinyl liner, inline UV bulb, automatic retractable cover
    JoyfulNoise's Avatar
    May 2015
    14,085
    Re: Overnight chlorine test + UV light
    Can you turn off the UV light and run the test again?
    Matt
    Feb 2017
    Pennsylvania
    5
    Good idea. Let me try that tonight. Thanks.
