Results 1 to 7 of 7
Thread: Trouble with multi port valve?
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    245
    Had my pool opened the other day. I have a Hayward sand filter. The guy had the multi port on recirculate before changing it to filter. He called me over and showed me how, when on recirculate, the pressure gauge was jumping back and forth between 24 and 28 psi. When he then switched it to filter the gauge just went to 29 psi and was not jumping anymore. He said that there should be very little or no pressure on the gauge when in recirculate which makes sense to me since it is not going through the sand. Anyway, I've always had higher than normal pressure according to several pool techs who have told me that on various occasions. The lowest it usually is is about 28 and will go up to about 38 psi and then that is when I backwash which sends it back down to 28 psi.
    The tech told me that there was something wrong with the multi port and that it could be fixed fairly inexpensively. My question then is should there be pressure on the gauge when in recirculate position and could something wrong with the multi port switch be causing the high pressure I have? It is my understanding that normal pressure on the gauge of a sand filter should be around 10 psi for a low after back washing. Thanks.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Jan 2012
    'burbs of Augusta, Georgia
    8,550
    Re: Trouble with multi port valve?
    Ned- does your gauge go to zero when the pump is off? Could the gauge itself be faulty? How old is it?
    Has anyone looked at your spider gasket under the multiport valve for shredding? I wonder if that is what he was talking about fixing??
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    May 2011
    lebanon tn
    370
    If your pump is oversized for your return plumbing the pressure will be high. If the pressure has always done this and filter works I would guess this is the case, especially with the high pressure in recirc. For example, if your pump is trying to go at 100 Gpm but your plumbing only allows 50 gpm the excess capacity of the pump makes your pressure higher than another pool
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    245
    Quote Originally Posted by YippeeSkippy View Post
    Yippee
    Yes, the gauge goes to zero when off. No one has looked at the spider gasket and that is what he was referring to. It just seems like it is unusual for the gauge to be jumping back and forth when in recirculate and then steady when in filter mode. Also, seems like when filter mode is turned on, pressure should increase much more than just going up 1 or 2 psi.
    I know this pump is oversized but I have 2" pipe. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S244T Sand Filter
    Jan 2012
    8,550
    If you're concerned about the gauge so much, just pick up a new one. They screw on/off. You may need a bit of plumbers tape.
    Get a glycerin filled one (oil filled) as they hold up better.
    Also get one that only dials up to 30psi as the increments are easier to read.
    If you are a bit handy (not much) you can replace your spider gasket easily. Videos on Youtube.
    Yip
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    245
    Thanks YippeeSkippy. This web site and you tube are what I depend on.
    30,941
    Sounds like two issues.....the flickering guage and the high pressure in your system.
    Replacing the spider gasket may very well fix your flickering problem. That's a pretty darn big pump for that smaller filter and I suspect that may be the high pressure issue.
    Yes, many pool pumps and filters have a clean psi of 10-14 ppm.....starting in the 20's is too high. Have you opened the filter to inspect your sand? How about deep cleaning?
